A couple more goodies from BlackBear Performance arrived today. I ordered the BBP skin for my AutoCal and to my surprise they also send a BBP decal.
Sent from my SM-G900P using Tapatalk
I'm drooling over here lol!
So new truck owner. What does this Bear tuner help you achieve in respect to your trucks performance. I own a 2015 Sierra Denali 5.3L 4x4 CC. Thanks in advance
Sent from my SG Note 4 on Tapatalk
Sorry "Black Bear" tuner
Changed my cabin air filter.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
DROPKICK Edition
DO 2015 Silverado have them ????
Yes behind the bottom glove box
DROPKICK Edition
DROPKICK Edition
i am hearing these get dirty rather quickly. How old was the one in your photo? Trying to get a feel for replacement timing without removing the parts to check. Lazy, I know...
Also, what was the cost? Wondering if K&N might make sense...
This on had 17k miles. Yes they do get dirty quick, and filled with leaves and stuff. I think it was like $13
DROPKICK Edition
DROPKICK Edition
thank you
DROPKICK Edition
You have a part number? Everytime I go to get one these part stores say that they don't even have a part number for one
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
