I have a 2016 Chevy LTZ z71. So I assume it would be the same. But I would like to change out my backup and license plate lights. Is it just a bulb change? Or did you have to put on a resistor? Could you tell me the part numbers of the bulbs so I can be lazy and not do any research on it? Thanks in advance.
Jim
check you owners manual , dealership . 2015 chev takes 921 (back-up), 194 (license plate) , or just pull the blub and look at it . just change blub, NO resistor .
That's right. I used Philips 921 for the back ups and cargo lights and Philips 194s for the license plate. If you are looking to do the back up lights as well as the cargo lights and 3rd brake light you will need 5 921s.
https://www.oznium.com/led-bolt
I used a black, aluminum housing, no lense, 16mm in each step. I used a dab of red loctite on each one to keep the nut from backing off. For the 16mm if you have a 5/8" drill bit it works perfectly.
When you have the step removed you look at the top and have the two mounting holes there. I just made a straight line between the two then measured to the middle (approx 3 inches) and drilled it. Simple and worked perfectly
Wired in with the led cargo lights in the bed, do not wire them in with the license plate lights as you can get a ticket for that bc you can't have white lights on in the rear while driving
Thanks for the info. This is something I will definitely look into doing on mine in the very near future.
I'm thinking if they are positioned at the back of the step they Would be a great additional back up light. Any reason you didn't wire them into the back up lights? Or any reason they couldn't be?
I put mine on the back of the step. http://www.gm-trucks.com/forums/topic/157013-what-have-you-done-to-your-k2-today/page-394?do=findComment&comment=1762767
When I do the cargo with reverse light mod they will go on in reverse.
I angled them a little bit down and out.
Edited by crewl1
I plan on doing some type of LED cube for additional backup light
I have 2668 miles on my truck and I am getting these SR-A's taken off. I have zero traction. I called Goodyear headquarters and they gave me a full refund. I just need to pay the difference in price. So now I have wrangler All Terrain adventure with Kevlar. Hope I like these.
Dang dude I should have tried that, I take it you're getting some different Goodyears put on there? I got $200 for mine at discount tire as trade in's and I was happy w/ that but, I guess I shoulda called GY..... I hated the SRA's one wet road and I knew they were junk.
What did you tell Goodyear to get them to do that? I'm both surprised and quite intrigued as I have less than 2500 miles on mine.
Sent from my SM-N910V using Tapatalk
Edited by Armyman22
Told them the truth of how unhappy I was with its traction. I told them I had no confidence in my truck do to their tires. They wanted to keep me happy. I still can't believe it myself. But. I had to get a different Goodyear tire and pay for the difference in price and pay for mounting and balancing at a Goodyear dealer. But on the upside I was able to add road hazard and lifetime rotation and balance.
Well headlights are next for me, had the HID's hooked up incorrectly before so gonna take another shot at them! Maybe I should actually get that deer damage repaired first though, hmm....
Damn you hit a deer in the High Country, any pictures of the damage?
Pushed the front bumper in on both sides (hit two deer). Broke driver side headlight housing and part of the grille. Barely noticeable unless you look. Fixed the broken headlight with JB Weld PlasticWeld lol I don't think I have any pictures. Some chipped paint up front as well
wow.. sorry to hear that.. at least you are not hurt, but that always bites when things like that happen
Well was finally able to save enough to have a productive weekend.
Installed an RC 2.5" level upfront
Removed front air damn
Added Method Mesh 17x8.5 0 offset wrapped in Toyo ATll 285/75r17's
Installed 14" Magnaflow exhaust dumped after the axle
5% Tint all the way around
Installed XB Led fogs (man were those a PITA!)
Attempted to install a 55w Silverado Spec kit from TRS, but had a bad ballast.
(still waiting on a K&N intake)
Edited by Boogie651
Hit the first one at 45 killed it on impact. Didn't do as much damage as I thought it would. Second deer I was going 55 and saw it coming across and slammed on my brakes, it was a love tap at around 20 lol
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
