Just ordered a set of AMPs from Morrie at TonneauFactoryOutlet. Hope to have them installed this weekend!
I bought a tonneau cover from AutoAnything and for whatever reason it wouldn't be able to ship for a couple weeks. I saw your post and went online to TonneauFactoryOutlet and spoke with Morrie.. He beat AutoAnything's price (that was already priced matched from around the internet) and the cover will be here Thursday.. I could have even picked it up today if their Houston Warehouse was a bit closer to me. I ended up cancelling my AutoAnything order and buying from him
Edited by sneakypete6
High country grill, painted to match
cccf1216-b65a-46d4-9ec9-6c463a1f0b9e_zps
The grille looks great but I doubt it's a High Country grille since you have a GMC :lol:
  • Like 6
Morrie is good people. I've ordered 3 things from him since December (Revolver X2, Pop&Lock, and AMPs). I hope you mentioned that you saw my post on the site.
Edited by blwright
He called me after my order went through and I mentioned I saw a post on a forum and that is why I decided to go on their website (I did not say the forum or you by name though). But that phone call was after I already paid for the cover, so it did not play into the price he gave me.
Haha you are absolutely correct. I will go back and fix the description. Thanks
Here you go, took them this morning. Makes me want to do more lights now haha88e2c67839d49f5fc4d8e67dfb27fedb.jpg
Im sooooo doing this ^^^^ thats killer
Thanks bud!
you need more lights - rocker panel (running broads ) cab roof . www.recon Big Rig running lites .
Roof marker lights look like crap on stock 1500 trucks, only if it was lifted or an HD truck. The rocker panel lights would be cool if I kept my running boards on. If I ever lift the truck and put the running boards back on I'll be sure to do both. Did LED cab lights on my 02 and they came out awesome, I don't think I would wanna be the one cutting into a newer truck like this though. I'll let the shop take that chance
Decided to dip my toes in the dash cam world and Installed an inexpensive G1W unit.
Video quality seems pretty decent when viewed on the computer.
Installed a set of Timbren bump stops this weekend but so far I've only been able to confirm that they don't impact unloaded handling. Now I need to find a decent priced camp trailer to buy and tow.
Alright, here it is, everything I've done today. Pretty busy but well worth it. Got it cleaned this morning at the local car wash (did a decent job).
Got back home and started off by replacing the front pads and rotors with Power Stop brakes and rotors severe duty truck and tow model
Moved on to the rear assist springs, easy install. Also hit the u bolts with the impact to make sure they were tight
Went ahead and covered the front and rear bowties with black vinyl, need to redo the rear bc I messed up cutting it so a little gold is showing
And last but not least I finally installed my bumper step LED's! This is my favorite of all the mods I've done so far, it just looks cool lol
Love the LEDs in the bumper! Do you have a part number or link for the LEDs that you used? How are they powered?
https://www.oznium.com/led-bolt
I used a black, aluminum housing, no lense, 16mm in each step. I used a dab of red loctite on each one to keep the nut from backing off. For the 16mm if you have a 5/8" drill bit it works perfectly.
When you have the step removed you look at the top and have the two mounting holes there. I just made a straight line between the two then measured to the middle (approx 3 inches) and drilled it. Simple and worked perfectly
Wired in with the led cargo lights in the bed, do not wire them in with the license plate lights as you can get a ticket for that bc you can't have white lights on in the rear while driving
Edited by rdnckhntr94
I guess this doesn't exactly fall under "what I have done today" but this is what I have done since I purchased my 2016 Sierra SLT Z71 in late December. Just wish it didn't rain before I took these photos so the truck was actually clean.
Leveling kit
Ceramic tint on all windows including windshield
Black window surround
Paint to match mirror caps, door handles, and door bumpers
De-badged everything but GMC logos
Color matched the GMC logo
Weather-tech floor mats and mud guards
All Terrain Grille, painted to match
de-chromed and powder coated front and rear bumpers to match body color
removed front air dam
Amp Research power running boards
Back-flip VP Tonneau cover
Custom magna flow dual rear exhaust with black tips
New wheels with Toyo AT II Extreme 295/55R20 tires
Philips LED back up, bed, and license plate bulbs
I have a 2016 Chevy LTZ z71. So I assume it would be the same. But I would like to change out my backup and license plate lights. Is it just a bulb change? Or did you have to put on a resistor? Could you tell me the part numbers of the bulbs so I can be lazy and not do any research on it? Thanks in advance.
Jim
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
