Didn't you look over the order before they placed it? I have ordered a few new trucks and they always send me the GM Global Connect shopping cart printout for my review before they click send.
Well we looked at another truck on the lot that didn't have all the options we wanted last year, and the dealer couldn't find one in a dealer trade either. So I gave up. Well one day my salesman called and said they took the list of options I was looking for, and ordered me a truck with everything I wanted but not marked as sold. So if I didn't like I wasn't obligated. I asked on three seperate occasions, and they checked each time to see if the max tow was included. They said it was, and when the truck came in it wasn't, buy everything else was. I guess I'll get a new one at the end of April now.
Had a compustar Pro T11 remote start/alarm installed. 37b834d77a2da9c4f8ce667cd9185d7f.jpgc5e3135f5989172109378e5e1cafab0c.jpg
Sent from my SM-N920V using Tapatalk
does compustar work better , then the one that came with truck (range) ????
I didn't have remote start before. But it claims a 3 mile range.
THANK YOU
Thats a little further than my factory keyfob.
Sent from my SM-G900P using Tapatalk
Crafferty, what is your round about factory range. I have a factory one and its seems like it is a very short range. 300 ft maybe if I'm lucky
Sent from my Nexus 6P using Tapatalk
Mine is very short range too. I bet only about 100-150ft if I'm inside a blgd and by a window. I've had it not work a majority of the time if I can't see the truck. I had the factory remote start added by the dealer when I bought it and was told it'd work in the onstar app for the 5 yrs. Well that was wrong and the range sucks. If I would have known that I would have gone aftermarket with the 2 way communication so you know it's started.
Same as yours on a good day. But if I'm far away I just use the OnStar app.
Edited by crafferty
Same here. I got the 3 month or whatever complimentary OnStar but I let it lapse. I use the app if I'm in the house to see what my gas level, tire pressure is just out of curiosity. Are you saying that the OnStar app won't start your truck anymore. Again mine lapsed but I am still able to use the Nav in the truck and start the truck with the app...only thing I've noticed is the stereo would tell me the weather and forecast but that just comes up blank now if I click it. Not a big deal
My app will still start my truck and lock and unlock the doors. I don't have a subscription to on star. It won't do vehicle stats or maps.
Since the remote start was dealer installed and not from the factory the app never worked to start the truck. I can unlock the doors and that's it. After going round and round with onstar and the dealer I was finally told by the dealer that its not supported on dealer installed ones. Something about a module being different and the vin not being in Onstar's database. No way to change it to make it work. So like I said if I would have known that I would not have bought the dealer installed version.
how much? id be interested in one!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
