Fix??
New wires?? I kinda tossed the old ones away
Sent from my Note 4 on Tapashit
No, you need to get under the hood. One is loose.
I bet its that dam passenger side back one.... Had to get to that one from under the truck to get it off. Ill give them a re adjusting in the morning and report back. See if all is well......
I just HAD to fudge it up right before a big road trip.... Could have waited till i got home but nooooooo..... Lol
Typical! I've been down that road before. I bought a new motorcycle last fall and torn it down before I even road it one mile. Then misplaced a bolt lol
Sent from my SM-G900P using Tapatalk
Thats weight reduction where i come from lol
I tried MSD wires on my 02 twice in a row and they both gave me a misfire. Ended up selling the truck with them on there I believe, but never had an issue with ACDelco wires and NGK Iridium plugs, win win in my book
Haha its already a lil Ninja 300 ABS. Great bike, really good for a new rider like me.
If they keep on ill buy stockers and keep them with headers as well.
I bet i can take u in my colorado lol
Haha it tops out at like 106mph! Vroooom!
You got a picture of it shining on the road? And also a link to the light bar would be greatly appreciated!
No picture with the light on cuz I'm still trying to find the perfect spot for the switch. I powered it on before installing it and its pretty darn good for a $100 light bar.
Curved 4D 180w 30 inch OZ-USA®L ight bar spot flood combo Phillips LED off road 4x4 4wd race truck https://www.amazon.com/dp/B01BUMLFJ6/ref=cm_sw_r_sms_awd_nrw1wb7E6ZW0Q
How polite are the duratracs on the highway? Very loud? I have read conflicting stories on them.
Like any all terrain, love mine even after 12k miles
Do you recall what % of tint they used?
They used a Lamin X film and I don't think that they have tint percentages. They basically have a light smoke, like I have, or a dark tint. The lighting on these trucks are bad enough so I went with the smoke lol!
I installed some 10mm threaded bayonet jobs.
I placed them on the back plate vs the top of the step since I wanted it to shoot some light off to the sides as well as hit the edge of the step.
(We load equipment in the dark after gigs and am in the habit of setting stuff off to the side as I organize the bed, this way anything I put out there will be lit.)
No need to remove the bumper, but place something between the bumper and bed as you drill as the bit may catch on the soft plastic and pull in quickly.
The barrel light just screws in and after placing the backing nut you can tighten with appropriate open ended wrench.
Dabs of silicone applied with a stick will keep the nut from backing out.
Lights are wired to work off the cargo switch along with bed lights.
ebay link http://www.ebay.com/itm/2pcs-1-5W-T8-LED-12V-Hidden-Car-Eagle-Eye-10mm-Screw-Bolt-on-Light-Bulb-White-/141720785400?hash=item20ff3791f8:g:gSIAAOSwT6pVqIRU&vxp=mtr
I thought about doing that. Has anybody tried these yet?:
http://www.anzousa.com/2014-chevrolet-silverado-l-e-d-corner-step-5-function.html
Edited by sk
https://www.oznium.com/led-bolt
I used a black, aluminum housing, no lense, 16mm in each step. I used a dab of red loctite on each one to keep the nut from backing off. For the 16mm if you have a 5/8" drill bit it works perfectly.
When you have the step removed you look at the top and have the two mounting holes there. I just made a straight line between the two then measured to the middle (approx 3 inches) and drilled it. Simple and worked perfectly
Wired in with the led cargo lights in the bed, do not wire them in with the license plate lights as you can get a ticket for that bc you can't have white lights on in the rear while driving
Where is the easiest place to tie into the cargo lights? It looks like the harness runs up under the bed rails but I can't tell where you can reach it to tap in.
It was nice outside today so I finally got around to installing my Bilstein 5100's on the back of my truck. Now they are on all 4 corners and I love the ride. I definitely think it's better than the factory Rancho's.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
