Jose, did you make it home safe?
In Oklahoma city.... Looking for them street outlaws see if they want to run against my truck lol
545mi to go!!!
Sent from my Note 4 on Tapashit
545mi to go!!!
Haha they have some real badass' in Lousiana now too.
Sent from my SM-G900P using Tapatalk
545mi to go!!!
Be careful my friend.
They dont want none bro.... Truck too fast.
Finally got my tint done....went with 15 on the fronts and I believe they put 35 over the factory on the backs. Next up a level kit, and then I'm done.....thank god for this forum so I can watch everyone else spend their money.....wish I could do half the stuff some of you have done to your trucks. There are some great looking trucks on here.
545mi to go!!!
Safe travels! I make the trip from Fargo, ND to Waco, TX a few times a year to hunt and see family. That drive is absolutely awful until you see the "Welcome to Texas" sign, then the 16-17 hour drive seems completely worth it. "You may all go to Hell, I'll go to Texas"
I run Miami, FL to Erie, PA at least once a year. I know the feeling....
Driving in PA alone is enough to cause a headache.
I do Miami to Canton, Ohio in a day..... A very long day.
On that note... Happy Texas Independence Day y'all.
I cleaned a !@#$% melted plastic bag off my truck's my exhaust. Man, did that bag stink and made quite a mess. Yes, it was empty. Got out the heat gun, Scotch Brite pads and putty knife and went to it. All gone now. Not my favorite mod, but glad that's all it was.
  • Like 3
Just finish installing undercover tonneau cover BedRug and amp bed extender
Sent from my SAMSUNG-SM-N920A using Tapatalk
Did you get the undercover flex or the single piece hard cover?
Sent from my SM-N910V using Tapatalk
Finally home!!
  • Like 5
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
