I'm okay with doing a lot of things but messing with the airbag is not one of them.
It actually isn't that bad, give it a look online.
Sent from my SM-G900P using Tapatalk
Thank you. It was a HUGE pain in the ass, but i am thrilled with how it came out. Now I just need to figure out how to remove the trim from around the airbag because now that sticks out like a sore thumb
What type of adhesive is on the back of the wrap?
Sent from my SG Note 4 on Tapatalk
An adhesive that can be removed when the vinyl is pulled off if you choose to do so. Wrapping is not permanent.
Finally replaced the malfunctioning PlasmaGlow Fire & Ice tailgate lightbar with an OPT7 Redline light bar.
That looks good. I've been looking at the opt7 tailgate lightbar. My tailgate light bar is 15 years old, and it's finally starting to go dim. I don't know that it will make it putting it on another truck.
Dem YouTubes is your friend!!! I am currently doing white carbon fiber on my intirrior.
Sent from my Note 4 on Tapashit
Finished my interior vinyl wrap today. A big thanks to tootall87 for his advice and in helping me get this project done.
What vinyl is that & where did u buy it? Can u post a link? How much should I order to do the same trim pieces, I'll add a bit more for mishaps.
Makes me happy to see people use my videos. make sure to like/share and subscribe.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
I got a shit ton from amazon. Just 3M Di-noc and the color or your choice. Like i said i am doing white carbon fiber on mine at the moment.
You better have a lot of patience..... And order a set of exacto knifes and a heat gun. I did one with a hair dryer and it took forever.
Going to harbor fright for a cheap o one time use heat gun lol
This
http://www.amazon.com/gp/product/B0058DIDTY?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
and this
http://www.amazon.com/gp/product/B0059715BC?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01
was enough to do all the pieces with some to spare. Although I was lucky enough to only have to redo one piece.
Please post pics when your you're done, i was also thinking of doing mine in white carbon fiber.
Order a sample before you purchase a roll of it.
DROPKICK Edition
Well add one more to your list that used your videos as a guide.
After only one day with everything being carbon fiber and the steering wheel still in aluminum, I couldn't take it. So using your video as a guide I popped the trim out and got it all wrapped up.
The differences on my truck a 2016 where, I had the radio controls on the back side of the wheel, which just popped out like you said with a simple wiring plug on the backside and the airbag fuse is located in the passenger side fuse box.
Anyway, here are the pics.
  • Like 6
You realize that thin chrome piece around the GMC on steering wheel throws off the vinyl wrap!!! , jk but now you're thinking about it... Lol. Awesome job man.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
