Sterling Heights!!
Sent from my SM-N920P using Tapatalk
Oh damn, I'm in Shelby, work in Madison Heights though, so we probably do cross paths!
Sent from my XT1254 using Tapatalk
always happens around 17 mile and Dequindre around 5pm!!
I drive by there between 330/430 every day during the week, I'll keep my eyes out for ya, everything stock other than level and tires?
Spent all day washing both trucks. Ignore the ding on the door on my girls truck..... Some idiot backed into her a few days ago. post-143469-145789903347_thumb.jpg
Sent from my Note 4 on Tapashit
Spent all day washing both trucks. Ignore the ding on the door on my girls truck..... Some idiot backed into her a few days ago. attachicon.gif20160313_130529.jpg
looks good. I have a BLACK one that you could clean up ????????
Installed my 32" CREE light bar and removed that ugly front valance
Ill leave it spotless....
I should really start my own detail shop with the work i do and for friends.
Even all the mud and crud that was behind the wheelspost-143469-145791512439_thumb.jpg
I bought it! Now I need to start modding it :)
Pics or it didnt happen!!!!! [emoji1]
Proof!
53573AF3-98A3-4474-9AAE-6C1BA80667F8_zps
5ABA4402-B786-403F-88F6-AF4FB1C4F991_zps
Thats a sexy color!!!
What are your plans for it?? Other than make the payments like i always said lol
As of right now the list consists of:
Steps
Tonneau cover
Bed liner
Tinted front windows
Paint matched grill/bumper
In no particular order but the bed liner and tinted windows is being taken care of next week :)
OK , YOU got me on the heat, bin there. BUT you got the sun , sand , beech , ladies and a good look truck .
I got heat and I still own a black truck. They just look so much better
sent from Florida beech
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
