LOOKS GOOD . HOW do you like the hood ?? NOW if the truck was BLACK .
lol,
i am partial to white brother. Black in Miami, not a good combination.
i love the hood. we test fitted and had to do nothing. lines on point, it's heavier than the OEM so you need to watch out when is open, a little wind and it may land on your head (or worst). Very well constructed and it gives the truck a mean stance. fully functional too (the ram air)
my setup... 2016 Silverado LTZ 5.3 6 speed Just installed the Rough Country 2.5 lift/level kit along with a set of 275/65/20 Cooper Discover AT3's here is some pics...
How do you like the tires?
sent from Florida beech
So far so good quiet and smooth on the highway tread pattern is very nice much firmer ride compared to the s**t sloppy goodyears!
lol,
OK , YOU got me on the heat, bin there. BUT you got the sun , sand , beech , ladies and a good look truck .
That we do, plenty. And the ladies love big trucks ;)
If we only had LA weather, Miami would be paradise
Rain, hurricanes, tornados, 99% humidity and 95 degrees ruin the party lol
Today is nice, perfect for washing
40EAD251-A6F6-42D3-8B25-C2EE447D10CD_zps
Edited by Sal9012
  • Like 5
Got this delivered today. Hopefully I can get it and the BedRug installed this weekend!
Sent from my SM-N910V using Tapatalk
Just got one put on mine
Sent from my iPhone 6+
Just a wash, hopefully the snow is done here in Michigan!d55757cdf2c29ec4f71a442e243f44ea.jpg9f07979bf2cc90140d57bdebe318d93e.jpg
Sent from my XT1254 using Tapatalk
What lift/level and tires? And do you have spacers? Any rubbing? Nice look
what headlights or what did you do to them?
Thanks! It's a procomp 2 1/4" up front, stock rear block....Trail Grapp's in 295/55/r20....Phil at Fastheadlights did the heads....FX-R retrofit with some custom paint as well...
I thought the SRA Goodyear tires where the worse tires I've ever had. I got Goodyear to buy them back from me for full price. Now I have Goodyear A/T adventure with Kevlar. These tires are better in 2wd than the SRA's in 4wd.
Nice looking truck!! I have the same set up but mine is iredum metalic!! And I swear I have seen your truck almost everyday I'm in Michigan to
Sent from my SM-N920P using Tapatalk
Dig that stance!!!
Sent from my SG Note 4 on Tapatalk
Where in Michigan?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
