I'm on a Tapatalk so excuse me if this information is in your sig. But what tires did you come from? I know some people don't like the stiffness of larger tires with 10ply.
Sent from my SM-G930V using Tapatalk
I had dick cepek fun countries. In a 35/12.5r20.
I dropped the size about 2.75 in or so. Didn't think it would look too small. But I guess it does.
Threw on some 305/50 Nitto Terra Grappler G2s. Rb10s will be here next week and going to attempt to trim my valence tomorrow.
Not going to lie but that looks horrible. Tires look way too small for your lift.
Here's a look with it not jacked up.
Edited by smcgillis10
Sent from my SAMSUNG-SM-G930A using Tapatalk
They are ~32" the 35s I had were only 34.5.
Why so small on that lift?
Edited by Daryl Z71
Wanted a tire that was easier to come by. One that road better. Got good mileage out of them. And something that might give me a little better mileage.
But why lift it then?
Edited by Daryl Z71
Ground clearance.
I've seen a lot of truck on here with huge lifts and only 35s. What's wrong with a 6" lift and 32s?
That's still ~3" taller then The factory tires that were on here to begin with. Maybe some people like a medium tire on a lift? And last. It's not your truck.
Ground clearance.
Chill man it was just a question. And my stock slt sierra stock has 31.2" tires on them. But sorry for offending you just wasn't sure why you'd skip leg day.
  • Like 4
275/55s are 31.9" FWIW
Installed the chrome tow hooks I had left over from my 08
7FD98F96-F515-4CA2-B83C-EAF68DB641D7_zps
  • Like 3
looks good
Finished up the passenger side truck bed this afternoon. Hoping to get the whole rear end of the truck into my local Line-X dealer this week. Then next week start on the front fenders and passenger side doors. Still looking to order a hood as well.
Will edit and add in the primer picture later.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
