photo's when installed ? PLEASE
Here's a picture of the hood installed. Still needs prep, paint and final fitting.
Sent from my SM-G930V using Tapatalk
I would if I didn't need the hood to replace my dented factory hood. I learned that getting a new hood is an incredible pain in the ass.
You could have my factory hood[emoji57] $500, my hood, and a shiny nickle.
- Mike
IG: @BlackPearl_Edition
looks good . BUT your hood would look better on my truck ????
Simple fix, just buy my truck once I'm finished next month!
I think the hood will be cheaper ??? beside I like my truck (made my way). that hood will look great when painted .
That looks mean!
Love that good! One day I'll get one.
Got some rcx traction bars installed
Sent from my SAMSUNG-SM-N920A using Tapatalk
Has the ride quality been affected much?
Not at all that I could tell. But there was a huge difference when I switch out shocks.
RCX 7" lift? And what shocks do you have now?
- Mike
- Mike
Those look like bilstein 5100's
Sent from my SM-N900V using Tapatalk
Decided to burn some rubber and deafen some neighbors. Curiousosity got the best of me and had to see what the truck would sound like with the Y-pipe removed so there's nothing but headers (no cats)
- Mike
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
