Hey all, I am having problems with my brand new silverado starting. The this in 4 days old just rolled it off the lot and this is what is happening to me. The past 2 mornings and last night when I was getting ready to leave for work. I went out to start the truck and all I get is a single click when I turn the key in the ignition. Try it again a few more times and the same thing has happened. I quit for 5-10 minutes after trying and go back out and try it again. It fires up first try with no problem. This morning I attempted to see if it was a battery problem and tried to jump it with no success. Wasn't sure if it was a loose contact so I wiggled the steering wheel and shifter and still no results. Brought it into my local chevy dealership this morning after having the same issue and finally was able to get it started. They hooked it up to their computers and checked it all and said their was no errors reading. They told me they were going to contact GM via their help portal and still have yet to hear anything. I was wondering if anyone else is having the same issue. I also posted a video this morning to Youtube showing what happens when I first try.
this is obviously only a short term solution but have you tried starting it remotely and then putting the key in?
We just bought a 2014 silverado last Wednesday. It wouldn't start on Saturday. We jumped it brought it in and they said there was nothing wrong with it. We brought it home again went to start it in the morning and its dead again. We towed it to the dealership where they can not find anything wrong with it. The truck has 180 miles on it. Which have basicly been used up driving to the dealership and bringing it home from the dealership. The dealership is 50 miles from our home.
I read on here somewhere that some trucks had a problem with the starter solenoid not making contact because of too much grease or something around the contacts in it. The solenoid pulls in but the engine doesn't crank over.
I believe one of the BCM updates addresses this very issue. Separately, I discovered one of the terminals on my battery was not totally tight on mine, which caused weird electrical problems that went away once the terminal was tightened.
The batteries that come on the 14s are pretty pathetic if you ask me. I live in Canada and we have had quite a few -30 and lower days now and I have had to use my booster box a lot now. I went into the dealer yesterday about this and they said they know the factory batteries suck as a few people have complained to them. I've also noticed the truck turns over for ever before it will catch when it's cold out which drives me nuts. Hopefully GM will give us an update for the cold start start problems.
Exact same problem here. Had the truck 5 days now. Either with remote, onstar, or key it seems to have a mind of its own. Same thing when I took it to the dealer yesterday.
Update on my situation. Leaving the truck at the dealership overnight so they can run a test on it in the AM. Will update when I get called tomorrow.
I plan to make use of that extra battery tray.... I wonder if that would solve your problems?
What is the cranking capacity of the OEM battery? This whole thing stinks. I have never, ever had any starting issue with my truck and it is 8 years old.
I'm anxious to hear what the dealer experiences and what they have to say.
giloma - when yours wouldn't start, did it even crank? If not, the jump start might not have really been needed. As with my issues, you try to start it and it just clicks (no starter activity), wait a bit and try again and it fires right up. The batt is strong. It may have been a result of the timing rather than the jump starter. OR... you had a low battery :dunno:
    RichardRS
    RichardRS
  • Who's Online   2 Members, 0 Anonymous, 785 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
