Tailgate seal
irish02bk
I have added an Access Larado rollup cover and a bed rug. I washed my truck the other day for the first time and noticed that water is getting in near the tailgate, anybody use any tailgate seals to help prevent this. I especially need this in MN, because if water gets in and then it freezes it will freeze my tailgate shut.
I have used both of these. As Nationalminer said, it is not water tight, but it does reduce water and dust intrusion from around the tail gate.
Access TrailSeal Tailgate Gasket
http://shop.agricover.com/product/trailseal
Extang Max Seal:
http://www.amazon.com/dp/B000CN5QG8/ref=pe_385040_30332200_pe_309540_26725410_item
In addition to the custom seal kits, you can also go to Lowe's/Home Depot and buy black adhesive foam weather stripping. It's usually about 1/4" to 1/2" square, 8-10' long, with one edge peel & stick. If you install it on a clean surface and give it about 12 hrs to fully adhere, it works great.
Agree with Moto^^^ I'm using the cover off my 2012 Silverado and it seems to seal pretty good. Could be better, but I'm not to worried. I don't have a bed rug though.
Install it just on the tailgate or around the whole tonneau cover?
I have a Roll Bak and only used adhesive strippings where the cover meets the tailgate and a few spots in the front where the canister sits against the truck bed. If your cover has rails that mount down the bed sides, I wouldn't recommend trying to put stripping under them, as it's too thick and would probably cause more problems than correct.
The stuff is pretty cheap, so you might want to just go buy a roll (it's near the doors & windows at Lowe's) and experiment with it. It's not too hard to remove if it's only been stuck on for 10-15 mins.
Same here I transferred a Xtang Trifecta Signature (canvas) Trifold from my 2009 truck to my new 2014 GMC Sierra Crew Cab SLT Z71 4x4 and it seems to fit OK except that the factory bed rail caps on the 2014 are pretty thick and hold the cover up and it does not seal across the tailgate and the front of the bed. If it ever warms up a bit here (man so sick of cold weather) I am going to see about maybe adding a piece of gasket of some kind to fill the space. Bedrug is ordered and should be here by Wednesday. Love this 2014 except for a couple of small issues.
  • 3 weeks later...
I purchased a tailgate seal set from Retrax when I purchased my Retrax Pro tonneau cover (ordered direct from Retrax)
  • 4 weeks later...
I will work on the tailgate and see, I was also wondering if anybody has used this? i figured the clear would work well if needed o the sides...
http://www.walmart.com/ip/As-Seen-on-TV-Flex-Seal/20850472
I think this might work , if you mask off carefully and use something to keep it from adhering to the tailgate. It would be nice if there was a product molded to just the right shape to seal this area. Dust always seams to get in this area.
I once put this tail gate seal on my new 2002 Chevy Silverado. I followed the directions and didn't over do it etc. I couldn't open the tailgate after I closed it. I had to really pull on it for some time and the tailgate finally opened. Once it opened, I took everything off and was happy I didn't have any further problems with the tailgate. Has this material changed since?
I have an undercover classic so the gap on the top of the tail gate is covered. However I did add a tailgate seal for dust. It works fine. No water and very small amt of dust on dirt roads. The seal also comes with foam bocks to block the bed openings by wheel wells and seals for small holes here and there. That dust is Not an issue with bed rug as you will not see the dust from those gaps.
    JohnRoy
    JohnRoy
  • Who's Online   4 Members, 0 Anonymous, 626 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
