In the 90’s you could push the parking brake just a tiny bit, the truck figured you were parked and turned them off. Not sure what that did on the dash board. If that still works you could deal with the switch.
when I turn the headlights from automatic to off, does that disable the DRL,s?
Forget where I saw it, but, SUPPOSEDLY, you can do the same thing with these trucks.  Believe the wording said that you had to push the pedal down two clicks.  My Ridgeline was one to two, beyond that, the brakes would "rub."
I modified the switch to remove the spring allowing the dial to be turned all the way to the left.
On 2018-01-15 at 2:32 PM, Kohl531 said:
I have a 2014 GMC Sierra WT that is Canadian.  Will this mod work for my truck or just the silverados?  Sorry I’m new here
It will work if you dont have the LED headlights. I know there have been wiring diagrams posted but still use a test light to find out which wire is hot with the low beam on and again for the amber light just to be sure you have the correct wires. Then swap their positions in the truck side of the connector.
I'm sorry, but this whole argument about the safety of DRL's is stupid. If you need headlights to see in the daytime, or if you need someone else to have headlights so you can see them in the daytime, then you don't need to drive. That being said, my DRL's are off
  • 4 months later...
On 1/30/2014 at 11:07 AM, VMaxtastic said:
Why? They're for safety. Not sure if you've ever seen the result of a head on collision... I bet you would change your tune if you did.
If you can't see a car in the daylight, you shouldn't be driving!!!!!
On 9/13/2015 at 5:19 PM, Matt DiMarco said:
Correct... its very simple, just need some very fine point tools to get the pins out of the connector. Start by removing the 2 grey peices. there is one on the front and back of connector.
On 8/30/2014 at 9:13 PM, flyin99 said:
Check right next to H. Here is the list of both plugs for each headlight, with wire colors.
On 9/9/2015 at 10:42 PM, Matt DiMarco said:
On a bright and sunny day, it looks dumb to have your low beams on, also, the bulbs will burn out a lot faster. However, LED's or Ambers (orange parking lights) can add a nice touch in the daylight.
Say I wanted the ambers for DRLs insted of the low beams, could I just cross the power wire from each? So the ambers come on instead (when I shift out of park). so then one click right on the light knob would actually turn on the low beams (i dont care because i have no use for this setting). and then obviously 2 clicks right would be low beams and ambers together, as usual.. and the auto night lights would work the same and not be affected.
On 9/13/2015 at 2:53 PM, Matt DiMarco said:
I just switched the locations of low beam supply (pin B) with the park lamp supply (pin E) in the connector. No cutting or splicing wires. No relays. No modification. Can easily go back to stock. Now only the orange parking lights come on during the day when in gear, and it looks sweet. The low beams will come on when I turn the light switch, or when the auto nightlights are tiggered by darkness. This is only confirmed for Silverado because I think the Sierra uses the LEDs for DRL not low beams.
On 9/13/2015 at 4:25 PM, Matt DiMarco said:
Just unplug the right or left harness and use a test light to see what pin is hot when low beam is on. and then what pin is hot with parking lamp on. diagrams were posted a few pages back so you can see which pins are which (ABCDEFGH) D,G and H are blanks. if you dont have a test light, im pretty confident that B is low beam and E is parking lamp. If you cant find the diagrams... when looking straight in the connector there is an upper and lower row or pins, 4 slots per row. upper right corner is A moving left to D. lower right corner is E moving left to H
On 9/13/2015 at 5:13 PM, flyin99 said:
So you're just swapping B with E in the plug and vice versa, E to B? I must try :) Thanks!
Ok, after digging through this thread, I quoted all the relative information. Has anyone tried this on a 2016 Silverado 2500HD with success? I am wanting to run either LED's or HID's but the DRL function obviously kills this idea. I also despise the DRL feature and would love to have it disabled. Would you be able to just un-pin the DRL supply voltage wire completely out of the plug and not have to worry about swapping it?
If you skip to 3:17, you will see the plug this is referring to:
Edited by SouthPawCO
For anyone that is curious is my above post works, it does 100%. This now allows my HID's to run 100% perfect with no issues with the 9v DRL. It also deleted the standard headlight DRL and now my park lights are my DRL. I would suggest this anyone that is either wanting to get rid of the DRL headlights or run HID/LED's without have to buy/use the relay kit. Now its plug and play.
  • 3 months later...
if you drive much or slightly fatigued the DRL makes it easier to notice the vehicle and the system also turns the headlights on in dim situations where the lazy, tough guy, does not.....again yes for safety. It amazes me how many people have newer vehicle driving down road with no lights on when almost dark....just not sure what the point is. But hope somebody who does these mods to disable safety and gets in accident, with damages....looses a mega lawsuit
On 3/1/2014 at 7:07 AM, mcnwil said:
Update. My LED DRL's have worked as designed all week, I am now checking them in glass when I pull into work, stores etc. It appears now that I am partly to blame as I mistakenly thought the green light should be on. This was probably due to me coming out of the garage in the am when the auto lights are on, and or going to and from work at twilight. I now suspect that the battery disconnect did resolve it but I was hung up on the dash light. The auto function, fog parking lights, etc. all work fine. I will now watch in glass windows for the DRL's but I do not expect an issue.
I now will move on to adding the HID kit. I think I will disconnect the battery from now on prior to any electrical work as a precaution. I do not think there is any harm with the electrical mods if done correctly, it is just that the processor apparently can sense load/resistance and a script or process can hang.
I hope you just solved my problem with drl lights.they work with my park and headlights,but not in daylight.just bought the truck so i will disconnect battery and try that.Thanks Guys
  • 8 months later...
On 4/14/2014 at 8:26 AM, RyanbabZ71 said:
Why is removing the drls such a big deal? Is it legal to bypass a safety feature?
Ryan
The DRL’s these guys want to remove are the low beams on Canadian Silverado’s. The low beams on these Canadian trucks are on all day every day when in gear because it’s the law in Canada to always have daytime running lights on. I have one and it’s annoying as ****. I bought some new projector headlights with LED halo lights that act as DRL’s (wired into marker lamps) but they look like ****** when you also have the low beams on. I would love to have the ability to turn the knob to the left while driving and turn off the low beams, but that’s only possible with Silverado’s made for the states. I’ve been scrolling every thread about this to see if anyone has an answer and have yet to find it. Hopefully someone that knows the answer will read this and tag me in the thread that leads to the solution!!!!
Do not know the answer, but what lights are on when you just use the park lights?
This is what my truck looks like when I just use them:
This issue is for the 14’s and 15’s that were built in/for Canada. They don’t have the nice LED strips for DRL’s. It’s the low beam bulbs instead. And with Canadian trucks, you can’t turn them off unless you’re in park, no matter what! It sucks!!
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 843 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
