Got the new bumper '14 on my '12 so I thought I'd share before and after pics and some things I ran across.
Pics of '12 bumper. fitment and gaps were a little tighter than the new '14 bumper.
For those that are particular about the millimeters, you decide.
Note the two bolts supporting the bumper
One side of the bumper attachment. Easy to get to.
Wicked little bracket that holds the spare tire access hole. Pain in the @ss to get out. Gotta bend each little tooth out so the plastic collar can back out.
Broke a locking tab getting the round trailer receptacle out. No biggie.
Evil little collar that holds the spare tire access tube in place. Fu$k it. Ebay has them for $8.
Edited by shortnugly
No worries with the broken trailer receptacle. The '14 bumper takes a whole different unit.
Yes, got the new dual receptacle on order. $32 shipped from GMpartsdirect
Twist out the license plate lights. Left and Right.
Pull out the wiring loom retainers. 6 of them along one edge of the bumper.
Wide shot of the back of the '12 bumper. Wire loom removed.
Thought I had to pull back the bottom plastic shield to get to the nuts that attach/support the middle of the bumper on the top of the receiver bracket. I didn't. the two bottom bolts came out without spinning the nut.
Lucy - Da Boss - She's head of Quality Control
No need to remove the bottom plastic. Cool tool though. Panel remover. Must have for any body/trim work
21mm to remove the two bolts that attach/support the middle of the bumper.
Safety comes first . . . . . . Stay hydrated.
One last shot of the old bumper.
Bracket on the inside of the right and left. 18 mm nuts.
Two nuts that remove the inner bracket. 18mm. Smaller bolt to the right is 15mm.
More shots of how tight the old bumper is.
Aligning bolt on the underside of each bumper to frame attachment point. 21mm again.
Bumper off. A little drafty.
'12 on the left, '14 on the right. New one is slightly longer. next shot shows the difference. Here they're placed evenly.
Shot of the other end shows the length difference. 1 3/8" longer on the new one.
Length view
Difference of 1 3/8"-ish
Overall length shows the new bumper is wider, ie: extends and wraps farther into the bed side. Better shots later show this.
New bumper wiring harness. Includes backup sensors - which I didn't use. I pulled the new harness off.
Re-used the retaining clip found on the new bumper for the spare tire access collar. Just bent some of the teeth back in so it would grab & hold the collar.
Old license plate illuminating harness. New '14 has different connectors. I used the old harness. '12 bulbs twist in to the '14 housing. Nice break.
Leave it.
'12 trailer wiring harness. I used the existing one. Detach from the back of the old bumper-mounted receptacle.
It will plug into the new GM dual receptacle part # 22799842. NO cutting or splicing was required because I had no backup sensors.
Corner shot with the new bumper on. Step flares out a little but still pretty clean lines.
Great utility. I really like the look.
Side shot. The upper corner radius is smaller where the old bumper had a larger corner radius. Nitpicking here but wanted to point out all my observations. No one but me will ever notice.
Old bumper for comparison.
Good, tight fit against the bed.
New bumper is "thinner" so the receiver protrudes out a little more. Not a problem for me. Better access to the hitch pin.
Old bumper shot for comparison. Covers the receiver tube more.
Look at the difference in bumper widths. '12 bumper is wider.
Tucks in nicely.
Shot of the bracket that supported the old bumper.
3/4" space. Gonna fab up some aluminum dowels to wedge in there on both sides. Tap one end and secure with a fender washer.
New bumper sits up against the bed.
The gaps on top were ever-so-slightly wider than the old bumper. So if you walk out of the store and catch someone back there with a millimeter ruler, punch him right in the left ear.
Old shot for comparison.
Hope all the pics helped.
Found the bumper for $550. Will sell the old bumper for half that so for about $200 + $32 for the '14 dual trailer receptacle - - - Good investment.
One afternoon's worth of time Pretty happy with the results
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
