Aftermarket LED Daytime Running Lights (DRL's)
LTZ2014
Man these look awesome. SO bummed Chevy didn't pick up the LED DRL like the GMC trucks did for 2014.
Unfortunately for me I have 2013 silverado anyway so it wouldn't have done me much good...
has anyone seen any nice adaptations of LED DRL for the 2013-2007 models? It's like finding a unicorn on the internet to get a writeup of any nnbs silverado's with nice looking day time runs.
Anyone seen any writeups or products?
  • Replies 188
I'm pretty sure putco has some drl like the ones for the 2014 but for the 2013.
Sent from my SM-N900T using Tapatalk
  • 1 month later...
Anzo, Spec-D and others sell complete headlight assemblies with projectors and LED DRLs.
Why would you buy a Chevy anyways? The GMCs are the same thing but much nicer.
they are literally the same truck with different grill and headlights. How are they nicer?
  • 4 weeks later...
  • 5 months later...
I purchased a pair of led strips to install below my headlights and am looking for suggestion on where to wire them into. I have a 2014 sierra sle and plan to turn off drl's with headlight knob so the dull drl headlight doesn't look so fugly compared to the bright led strip
What kind of strips??????????????
I did this a few months back...
http://www.gm-trucks.com/forums/topic/168169-led-drl-envy/
I never heard back from them.
Ive got the same grille inset as you, how did you get the ltz badge back on after you installed the grille insert? also do you have a pic of your headlight led running light set up turned on?
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
