What are you towing with your 2014?
First time towing with this one. Have to say, pulled the ramp better than my 5.0L F150 4x4.
Man, tow haul mode holds the gears in this one something crazy.
  • Replies 458
3500 lb enclosed trailer up to 5k when loaded pulls great no problems. I really like the hill descent mode that came with the Z71 package it holds itself on a hill when stopped and helps on steep grades so you are not riding the brakes.
I've noticed it holding on stops but how or what does it do going down a hill?
I have not dug into exactly how it works but here is my experience. If you are descending a steep grade and are riding the brakes the system seem to either put the brakes on itself? and or use the engine to keep the truck at the same speed without you touching the brakes again. I thought it was pretty cool. It disengages as soon as you touch the gas pedal. On a incline if you pull up to a for instance red light and stop the system automatically holds the truck to keep it from rolling back now that is handy.
Pulled my travel trailer to a mud park this past weekend. I figure loaded with water and gear we were around 6500lbs. Silverado pulled awesome. Even in high side wind. Seems like whatever they've changed on the suspension doesn't let the truck want to walk in high winds like my 2010 did. Plenty of power, noticeable difference compared to the 2010. And the tow/haul mode is greatly improved. Just a little loud with the exhaust I have, but no big deal. I like the sound.
I pulled my 7000lb travel trailer and it pulled fine. Better than my Titan did.
I did notice the shocks were extremely soft, so I guess that'll be my next upgrade. It was kinda bouncy.
Haven't pulled anything yet since the boat is still blocked in with snow. But will be pulling a Regal 2565 to the marina sometime in April. 6200lbs plus about 1800 for the trailer.
I would do rear air bags. You keep the factory ride and just add air to help them. If you switch to a stiffer shock your ride without the trailer would suffer.
I'm an advocate of Timbrens over airbags. Super easy to install. No need for compressors or adjusting inflation. They don't really change the ride since there is still about a 1" gap.
Do you have these on your 2014? Or, is this based on past experience?
Past experience. I haven't put them in this truck yet, but will before moving the boat.
Got it. I'm trying to decide which way I want to go. Trying to negate some of the squat in the rear of the truck. It will look bad with a leveling kit and the rear squatted like that.
That's my concern also. The Timbrens help that and remove the full weight of the tow off the suspension. I've never had them in the rear before but have had plow trucks with them in the front. They worked awesome.
Remember, spring force (factory leafs, Timbrens, airbags, etc.) and dampening (shocks) are two different aspects of suspension. Shocks do virtually nothing to support the load. All they do is resist relative movement of the load. They resist movement...that's it. Note this assumes no cool air-over, coilover shocks, etc. Let's keep it simple.
If you're squatting too much, don't default to bags to help. Probably won't actually fix the problem which is, too much load. If you're not squatting but you're moving around too much during bumps, moving the load may help a bit, but additional damping may also. So, "stiffer" shocks. Be aware that this will probably sacrifice unloaded ride quality as well. Best of both worlds? Adjustable shocks, ala Rancho 9000x series or the like.
Trucks are really all about compromise. We want Cadillac DTS ride w/ Kenworth towing capacity. Noooot gonna happen.
    HWN808
    HWN808
  • Who's Online   2 Members, 1 Anonymous, 1,043 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
