What are you towing with your 2014?
Counting down the days (well probably months) until I can tow my boat. Going to be awhile up here in MN. From the sound of it I shouldn't have any problems pulling it, weighs around 5,200# w/ trailer.
  • Replies 458
Don't have pictures, but I hauled about 6000 lbs of raisins back down to my business a few months ago. I need to get a different pintle hook mount that's higher since the trailers I rent are pretty tall. I'll see after I do my leveling kit.
Coaster, that's a double cab correct? Aka the extended cab.
I saw a double cab Sierra on the street the other day and it looked very awkward which was dissapointing. Fortunately yours and others from the forum look very good and proportions seem "right".
I find I bounce a good bit down the road towing. I also find that I bounce a good bit unloaded. Probably will replace the stock shocks with Bilsteins and perhaps add air bags to level out. Need to make some adjustments to my WD hitch before deciding for sure on bags.
Leveling kits and travel trailers are probably not the best combination...haha.
FYI...I swapped my Timbrens from my 2011 to my 2014. They fit as intended and are easy to install. They work great when towing my TT to keep the load distributed. I'm not concerned much about hitch weight or squat as I am well within limits. Also anyone installing them they changed the bolt size on the 2014 to a 10mm head as opposed to a 16mm and they are much shorter. I had to buy new longer bolts for the Timbrens as they have a much deeper recess with the mounting plate. Thread size and pattern is still the same, metric for sure. They still allow for 1-1 1/2 inch gap between them and the axle.
I sacrificed one bump stop by cutting it off to find this out!
Yep it's a double cab. I think they look OK, maybe one with an 8ft bed would look kinda strange.
I only use the back seat for dogs and floor storage so I didn't go with a crew cab. I also didn't want the tiny bed or a longer truck.
Had something happen that hasn't happen in years pulling these boats with my Fords.....with boat hitched heading back to the warehouse I kick it half throttle to merge and the rear tires break loose.
Can only imagine what the 6.2L is like. For such a soft tip in on the throttle, these 5.3's spin up pretty fast.
It is even worse when using the E85 fuel. The 5.3 engines loves this alcohol fuel will set the tires on fire, be very careful if you try it.
What is the most you can tow without trailer brakes?
2,000 I believe is a federal DOT regulation....
From the owners manual:
Trailer Brakes
A loaded trailer that weighs more
than 900 kg (2,000 lb) needs to have
its own brake system that is
adequate for the weight of the
trailer. Be sure to read and follow
the instructions for the trailer brakes
so they are installed, adjusted, and
maintained properly.
Well, I have a 2012 Chevy 2500 hd, 6.0. I am currently pulling a 35 foot (37 feet with the hitch) travel trailer. Honestly I have pulled trailers my entire life and it isn't much better than pulling with the 1500 I had. I have the gasser and my trailer empty is about 6700 lbs....
I am looking at a either 5.3 or 6.2 with max tow package...which would push me up around 11K. I have a WD hitch but one other thing I would do is upgrade the tires. everyone think that will work? I am sick of the rough ride of the 2500 and I may as well switch back to a 1500 if it can pull...most likely get a double cab.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 436 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
