Dumb key fob question
I kinda feel stupid asking, but how can I tell which key fob is #1 vs #2? I see no markings.
So, I guess if the truck doesn't know which is which it doesn't matter. Huh. Ok, all of my "old"
GM products with multiple driver memory ALSO knew which key was used and therefore applied those settings.
We take a step back or something?
Yeah unless you have memory seats you don't need to know which key is which. #firstworldproblems
If you have memory seats:
Set seat memory 1 a certain way and seat memory 2 a certain way. Switch to 1.
Then use one of your key fobs and lock or unlock the doors and see if the seat moves. If it moves, that fob is number 2. If it doesn't, that fob is number 1.
Also make sure Auto Memory Recall is set to On in your Comfort and Convenience settings.
Pezboy, that's the process of elimination I was using. But, is the first fob used arbitrarily assigned #1 or did I just get lucky? I guess I'll need to sharpie it on or something.
I didn't think the remotes worked the memory recall as I didn't see them marked either?? So they actually do?
Yup. Just verified it. But you must have Auto Memory Recall is set to On in your Comfort and Convenience settings. I followed what pezboy said to test which remote is set to 1 or 2 and verified that Auto Memory Recall has to be ON for it to work.
Or a different tag or something specific on each key ring to differentiate.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
