how good are Glocks?
tonyghkbve
  • Replies 51
Glock has a really good program geared towards the military and first responders called the "Glock Blue Label program". I called a blue label distributor told them to hold me a glock 17 gen 4. Came in there showed my military id, filled out the paperwork, and i walked out spending only 432.00 including tax for a brand new handgun with 3 clips. Knocked a considerable amount off the normal price
If you join GSSF- Glock Sport Shooting Foundation for like $30/year you can also get a certificate to buy one blue label gun a year.
:M16: Glocks are OK if "polyomer guns" are your thing? People that shoot a lot will usually prefer a "metal" gun but as previously stated, they are OK for the money! :flag:
lol what? Glock has been selling in the US since like 1987. If they didn't hold up I think we'd know by now. And then there's HK, and they're easily the most durable/reliable mass produced pistols money can buy.
:M16: "We" do know! That is why the US military has never used a "plastic" handgun! :flag:
SEALs previously carried the HK Mk 23 and now carry the HK 45CT. Try again.
And your argument sucks, the military carries Beretta because we wanted to put missiles in Italy.
:M16: Uh, I was a Seal for ten years! We never carried a plastic handgun, and FYI the marines have switched to "Colt 1911's." Beretta is on it's way out! As a special operator for ten years, we carried what we wanted and back then we usually wanted 1911's! :flag:
You need to change your signature. SEAL Team 7 didn't exist until 2002. We have several veterans or are currently serving and I won't have you disrespect them by claiming false military service. You have until 9:00 eastern tonight or I'll do it for you.
Didn't know that but I'd also never buy a gun with a mag disconnect.
Mag disconnects are stupid and one more way they are trying to idiot proof guns. My Ruger P345 and SR40 (along with all the other SR series pistols) have it. The upside is it takes all of 10 minutes to remove that useless mechanism on the Rugers. Take off rear sight, remove spring and a little piece, replace rear sight, and you're done. If I couldn't remove it I wouldn't own it. Having said that my Mark III has the darn thing too but dry firing a rim fire is bad plus it's just more fun to shoot a .22LR anyway. I also don't shoot that gun w/o the mag regardless of it having the safety. My other guns I shoot occasionally w/o the mag just to get the last round out the fun way instead of ejecting it manually.
Great guns and do not require the constant cleaning like my Kimbers. Very, vey reliable. Will lay in a drawer/safe for a long time and shoot as needed. Just like a revolver. Pull trigger it fires. Accurate enough for protection and once you learn the trigger up take it can be shot with good accuracy.
  • 3 weeks later...
Funny I remember a lot of the SOCOM guys I knew had SIG P22? (Looked just like the P220) but chambered in 9mm. For me I like the SIG P220 series and the H&Ks.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
