Fuel Maverick 20x9 +20
Nitto Trail Grappler 295/55R20
Rough Country 2.5" Leveling Kit
No rubbing or trimming
That is one beautiful looking truck. Makes me almost regret not getting a black Sierra. Lol
Nah. It's always better to admire someone else's black truck, immaculately maintained, thru countless hours of washing, polishing and waxing. :jester:
from a former long time black truck owner.
  • Like 6
Did you have to do anything to get the truck to ride right? Or just wheels + tires & alignment and you were good to go?
It's leveled 2.5 inches using the Rough Country front leveling kit (stock rear blocks). That, plus the wheels/tires and alignment is all that's done to the truck.
You make me regret getting my Sierra in white and not black.. Love the setup you have!
Any time you're feeling regret you are more than welcome to come wash this gigantic black disaster... It only looks good in photos, I promise!
I went with the Cognito UCAs and keys. This raised it about 2.75". I didn't do anything to the back.
Wheels are 20x9 with Goodyear 285/60/20s. No issues. 4341cda5c9a9d47dd005a81ed064888e.jpgfd4e8809c792c8cf1b7755ec8cabd296.jpg5c80bd8252844a55f6953d0c9a3d410e.jpgf5ca6d12746c82fd6ae15bd42a8a3adb.jpg
Got any side shots?
I didn't want the wheels as close as I could to flush.
So they stick out about .5" or so? 0 offset
Correct. Really just the sidewall. I think the wheels are 5.5 bs.
Good lookin truck Skav. Top cabin on those Fox shocks. I think you live up by my brother.
Edited by spurshot
SCV?
I'm in Castaic.
Anyone have pics of lifted with stock gmc 20s want to lift mine but keep my rims and tires but will upgrade tires later
Leveled w stock 20s
Nice looking good but looking for pics along the line of the 1500 lineup I'm more than sure 2500 are higher than the 1500 especially since I'm 2wd
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 224 Guests (See full list)
