Dash Cameras...Why?
Spurshot
Friend showed me a dash cam video of 2 - 18-wheelers in a accident. One 18-wheeler (left lane) was over-taking another (right lane) on snow covered roads in Nebraska when the 18-wheeler in the left lane started to loose control and crossed into the right lane where it was T-boned by the truck in the right lane, at the just back of the rear duals and pushed down the road a long way and end up on the right shoulder. Both trucks were totaled, T-boned trucks cargo was scattered all over the interstate. The trucks were in so many pieces they brought in snow plows to clear the roads of all the debris (interstate shut down for hours). Without that video it was unclear to the police who was the cause of the accident and they were grilling the truck driver who hit the T-boned truck as possibly at fault as the driver who was hit claimed it was not his fault.
It was a friend of a friend and I just seen the video this past week.
Saw one video posted where a 10 car hauler had police waiting for him after he ran over a tow trucks safety cones. Had he not had a camera showing there was a U haul truck in the left lane & the tow truck was
around a corner of an exit leaving him no where to go without ample room to stop/slow down, he would have been written a ticket.
Is there a DVR type system similar to a home security system, that records continuously and over writes past recordings? I would want a system that records at normal speed while driving and either had several days worth of recording capacity when parked.
I would want to 2 camera system, with one in the front and one on the back of the topper.
I did not get the gps option
Ryan
As far as I know pretty much every dash cam does the "loop recording" thing.
You should have at least a 16 GB sd card. Better is 32 GB especially when the truck is parked for a longer period of time.
The lower the recording quality and the smaller the frames per second rate the longer is the recording time before the cam starts to over write files.
This is a site were you can get an idea about the different cams, the pros and cons and average prices.
http://dashcamtalk.com/
so long
j-ten-ner
this is exactly how they work and I have the dual channel in my lexus. 720p in the rear 1080p in front. they will hold about 8 hours of video I think on a 32gig microSD but the time it holds I have found is not that important. there is an app for my phone that allows me to connect to it via wifi, I can replay the video for a cop after the fact or live. once I find the file I need I can save it to my phone and upload to YouTube in a few minutes if necessary.
since the oldest videos get overwritten the one you want if it just happened is easy to capture.
also someone mentioned about the video being used against myself. 1 I would say I am a safe driver. 2 I control the data that I collected. it gets saved in 3 minute clips. I can decide what video I want to use and what I choose to discard. I can also decide if the video I capture supports my case or incriminates myself and use accordingly.
TY for the replies!
I know it seems like it wouldn't be a sought after item if seen, but we had a clarinet swiped out of our 'Nox, which is how we found out about the rash of thefts! Even a co-workers' kid had a gym bag swiped out their car, probably to make other thefts easier to grab, stuff & run!
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 870 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
