Anybody haul a canoe?
jrsmall0221
I traded a 2012 Xterra Pro4X for my 2014 Silverado DC Z71. I love my truck but need to figure out a way to haul my canoe. I'm thinking about building a rack for my bed. There are lots of ideas on line and on YouTube. Has anyone done this or have any other suggestions?
Sent from my Nexus 7 using Tapatalk
Depending on the size of the canoe, one sided ladder rack seems pretty cool. Removable as well.. Good luck!
I built my old rack out of 2X4s for uprights, drilled holes in the tops for the pipes from an old Yakima rack, cut down the bottoms for the stake pockets, strapped the canoe on rack via bed tie downs. Only used it 2-3 times a year so worked for what I needed at the time.
I have carried a canoe in different ways. One was on top of small car with foam roof pads. I carried in a larger trailer. The easiest way for shorter distances was in a 6.5' bed with it sticking out to the passenger side. I tied it in well and put a red flag on the end hanging. On top of that I drove defensively to avoid conflicts.
I put a back rack on my truck and put the front of the canoe on that and the back of the canoe on the tailgate works perfect for my needs.
I have a tracone universal ladder rack on my truck. It was only about $300. Should work perfectly for you with a foam block canoe/kayak carrying kit. I use it to carry my 14' long, 85 pound fishing kayak on a regular basis. Still getting 19-20 mpg on the highway with the kayak up there, two loaded up toolboxes on the bed with a bunch of stuff in them, and my two labs in the back.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
