Hi. I need some help installing the factory remote start on my 2014 silverado 1500. I know the dealer needs to program the fobs. The part I need help with is figuring out where the wire from the hood latch goes. I bought the gm 22997089 kit that came with the new hood latch with the pigtails coming out of it and the wiring harness to plug into the hood latch pigtail. The kit also came with 2 fobs with auth code.
The wiring harness has 2 wires, black and green. I am assuming the black is a ground and has a lug attached. The green wire I am assuming is for the hood ajar signal.
Does anyone know where to attach the green wire???
can you post a link of where you got it ? im interested in buying one. thanks!
Diagram for LD PU Harness Only
This diagram outlines scope of the Jumper harness for Remote Vehicle Start accessory:
Front of vehicle (1)
Plenum (2)
Plenum Grommet (3)
Harness Ground (4)
Hood Latch (5)
Procedure Remove Front Compartment Front Sight Shield
  1. Remove the front compartment front sight shield push-in retainers (1).
  2. Remove the front compartment front sight shield (2).
Updating the Hood Latch – Required for all non-UTJ Pickups
Harness is For Light Duty Trucks Only
Route 3-way connector jumper harness branch (2) along front of vehicle, in preparation for routing under Grille Mount Panel Bolt (1) and Bracket (3). Be sure to route in front of air baffle (4). As a general guideline (after driver side of the hood latch) route alongside the Hood Release Cable up to the Driver Side Hood Bumper located on the Tie Bar.
For Light Duty and Heavy Duty Trucks
  1. Remove and replace hood primary and secondary latch. Refer to Hood Primary and Secondary Latch Replacement.
  2. Make connection from the Hood Latch Pigtail (2) to 3-way forward lamp harness connector (1) (or Jumper Connector for Light Duty Trucks.)
  3. Ensure that the connection is securely fastened in the positioning locator for the connector. Refer to B55 Hood Ajar Switch.
  4. This Step is For Light Duty Trucks ONLY:
    Remove the 6.35mm hole clip with strap, which is taped to the harness (blue tape) and fasten harness (4) to the air Baffle (3) 6.35mm hole approx 4” (10cm) away from connector. Tighten strap clip and cut to length.
  5. Remove and replace grille mount panel bolt (1).
    Tighten
    Tighten bolt to 25 N.m (18 lb ft).
    Note: Ensure the bolt does not pinch the jumper harness conduit when fastening.
Installation of the Hood Latch Status Signal Jumper Harness (For Light Duty Pickup ONLY)
Routing the 3-way Connector Branch of the Harness (Light Duty Pickup ONLY)
Note: Use a tie strap, part number 11509086 (10 total in kit) to secure the harness to the hood latch release cable, after the hood latch, and before the hood bumper. Cut all tie straps to length.
Fasten the jumper harness to the Hood Latch Release Cable in one location along air baffle, using tie straps (1) P/N 11509086 from the kit. (midway between the two hood cable clips (2). Secure harness along hood release cable using two additional tie straps (3) P/N 11509086. Approx distance between tie straps should be 20cm. Cut all tie straps to length.
Routing the Ground Branch of the Harness (Light Duty Pickup ONLY)
  1. Route the ground ring branch of the harness along the washer bottle tube and fasten using a tie strap P/N 11509086, to the forward lamp harness head lamp connector branch. Continue to route in front of the bottle and in front of the fog lamp bracket. Accessing from underneath the vehicle, continue to route behind the front fender and fasten to the upper end of the downward branch (2) of the forward lamp harness (1) using tie strap (3) P/N 11509086.
  2. Continue along down to the ground stud G101 (1). Remove the ground stud and fasten using BOLT/SCREW-FORWARD LAMP WIRING HARNESS GROUND, tighten to 9 N.m for ground ring, noting there may also be an existing ground from the forward lamp harness. Cut all tie straps to length.
Underhood Routing of the Hood Latch Status Signal Wire (Light Duty Pickup ONLY)
  1. Following hood latch cable, route the signal length of the harness (1), inserting the harness into the C-clips (2), in two locations.
  2. Using tie strap (3), P/N 11509086, fasten in two locations between C-clips, maintaining approximately 20cm between fastening points. Cut tie straps to length.
  3. Fasten to the third hood latch cable C-clip and branch away and toward the body harness before the grommet (3). Fasten the jumper harness (1) to the body harness using two tie straps (2) P/N 11509086 evenly spaced approximately 20 cm alternating with clips. Cut to length.
  4. Route the signal wire conduit to the body harness grommet, ensuring to create a 3” diameter drip loop (4) before positioning the taped conduit end at the grommet for entry to the interior of the vehicle.
  5. using a utility knife, cut an 1/8” slit in the grommet (3) to prepare the entry for the bare signal wire.
Routing Wire through Grommet to the Body Control Module (Light Duty Pickup ONLY)
  1. From inside the vehicle, remove the fasteners and position aside the instrument panel wiring harness junction block.
    Note: Junction block connector removal is not required.
  2. Using a utility knife, cut an 1/8” slit in the thin hole of the grommet opposite of the exterior side. From inside the vehicle, insert the ¼” brake tube (2) through the back piece of the grommet (3).
    Note: Grommet removal should not be required.
  3. From inside the vehicle, carefully push the tubing through to the front of the grommet, exiting at the exterior end of grommet.
  4. From the under side of hood, insert and feed the signal wire (1) and terminal through the tubing (2) to the inside of the vehicle.
    Be sure to maintain the conduit drip loop just before the grommet entry. Verify that the grommet end does not collapse.
  5. Remove the steel tubing (2) and clean both the entry and exit surfaces of the grommet using cleaner P/N 9M905449 (US), 00992727 (Canada), or equivalent.
  6. Apply silicone to the grommet at both wire entry and exit, using silicone P/N 12378479 (US), 88861419 (Canada) , or equivalent. Leave to dry while completing the remainder of this procedure.
  7. Using J-38125-22 tool, remove any wiring in K9 BCM X4 26-way connector pin 24 (BN/L-GN) and tape back onto the body harness, if applicable. Insert the GN (green) jumper harness signal wire connector into pin 24 on the K9 BCM X4 26-way connector. Refer to K9 Body Control Module X4. Reinstall all connectors.
  8. Reinstall the instrument panel wiring harness junction block to the floor studs and install the fasteners.
Edited by newdude
Hey guys I'm on the fence about either this OEM kit or a nice viper. How's that extended range working out and is it adequate. Not in a real big hurry to do it.
The Viper are good they are long range they can go up to 1 mile. The factory can received up to 300 feet or little less or little more depend of things in the way or a big hill.
My dad has this Viper work great but you would need to get a harness for your model. if you got a Onstar system. Then you would need a harness for that as well. If you want to add more it got 4 more add on function you can look up add on remote for windows,hood,light, any function that you want to connect to.
Can any if you guys could provide some help and some information?
I've bought a new 2016 GMC 2500HD 4x4 Crew Cab truck 3 weeks ago and it does got the remote keyless and the tailgate lock too. As reading my manual I saw the remote start and my remote doesn't have one. So i went to bought a pair of a remote and I happens to stumble to this tread. It should have been a two chrome remote but I ended up with this packages that came with two black remote with a electronic hood latch that is able to use for your remote lock in key.
Can I installed this electronic hood latch on my 2500HD? The latch look the same. But would I need a wire or harness to install this to my system on my truck? Does it already have one installed? I just need to plug it in?
Does anyone know the parts number for the wire harness?
Much help would be gladly appreciate Thanks :)
I should have gone to this place to buy a remote. http://www.northcoastkeyless.com/2016-gmc-sierra-keyless-entry-remote-fob-programming-instructions/
IMO go OEM and make dealership install it. I am not saying one is better or anything but remote start is one of those things that is notorious for not working right or getting blamed for other issues. I think it is worth it to have a dealer do it just for liability, you do not want that and worth the install charge if you ask me.
The range is great on these. Surprisingly great IMO, you can also hold the key under your chin and open your mouth for extra range. I have got a good block if not more out of my FOB.
Edited by Alpine Truck Life
I had my dealership add the remote start before I signed for the truck since you can't get remote start from the factory on a WT for some reason...
But what does the hood latch have to do with the remote start?
I know all of these new technologies and features get kind of redundant, but the hood latch?
Edited by KaptKyle
That strange. The dealership did offer me before I bought the truck and then I changed my mind that I wanted one, so I order a remote that have a start button and this came with this package with a remote latch. But then they told me 60 bucks from the dealership to program the remote. But if I wanted a latch remote put on. Then it was cost me another 100 bucks it just a harness for the remote command in the dash does automatically connected. What the guy told me. It just a program that it have inside the remote command computer and it does the rest. But i am going to see whats up tomorrow. And find out if i can get the remote start on this truck. I hope I could. Would be retarded that you can't. My GM center https://my.gmc.com/homeask if i wanted to buy a remote start for it too and have the dealer ship put it on for a 250 bucks.
This truck is just a regular sierra 2500 HD with the trailer package and convenience packages w/ 17 inch rims and remote keyless lock and key with a tail gate lock and key and does have a back cam. Does that mean I got a WT?
The hood latch is so the system knows the hood is shut. You can't remote start the truck with the hood open.
Ok guys I found out.. If you have a AQQ remote system it will just work as keyless system. You would need a AM1 - AP8 or AQP8 in your RPO. Another word you would need a LT/LTZ SLE or SLT ECU remote module system. I heard one guy said you would have to plug in the fuse and add few wires to the remote command module it order for it to work. I don't know what part number that would be. But I just wasted 190$ plus 60 bucks for programing my remote I thought they knew what they were doing. Pretty much disappointed.
I hope I can return the remote with the latch packages back to this guy on ebay
If you have a regular Sierra or a Chevy 2500HD or 1500 it has no start remote. Now if you had it order from the manufacturer with the remote packages it will add that. You can add it on the truck but you would need to contact the manufacturer from GM they could provide the little computer for the Keyless remote entry with start.
Don't be fooled by the www.gm. owner center they will just give you a FOB remote with no RCU.
So you are better off going to Best Buy or some car Audio place to add in a Viper with a remote. They have the diagram to add a remote start and better car/tuck alarm system.
Yes that is correct. But Also the wire does tell the remote system to fail when the hood was pop open from being started. So you won't be robed. I thought it was a pulley that let you remotely pop open they got that motor for that latch it on ebay it the same way for that unlock tailgate. Pretty much it.
Thanks guys. I took my truck back up there at the dealership to have my alignment fix this is my 2nd time hopefully they fix it only got 481 miles on it. it pulls to the left real bad
Edited by TexasMidnight
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
