Got a new car...
mike94silverado
8yny7enu.jpg turned in my 11 Malibu lease on a new one... As disappointed as I am in GM for how they have treated me I liked the car and the price was right and everything we hated about the 11 has been corrected on this one happy so far
Yup good looking car. I also really liked the design of the previous gen Malibu as well.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
