Made the back more kid friendly. The guy who made the roll cage obviously didn't have kids. Look at the angle he put the belt bolt on point. Could have been straight up and down.
Stayed up til 11 wiping it down for C&C this morning
Then I see this
Which actually means 100%
LSA is kind of a rip off when you look at other GM crate engines. That doesn't eve include the wiring harness and ecu, another 2k at least. You can get a 525HP LS3 WITH all the electronics for 10K, and its all motor.
A lot of Camaro guys are getting used LQ 6.0 engines and harnesses for 2K for cheap LS based swaps.
Edited by SnakeEyes
Woke up, watched the weather(you already know where this is going) local weather says slight chance of rain, all the major stuff has passed, Tulsa might get a shower in the next hour, otherwise everything will happen west of Tulsa County.
So I drive the bird to work. All is well, the showers never showed up. So I see some clouds to the east( I work east of Tulsa)..hmmmm....hour later, I see rain east of Tulsa. Uh oh. I check weather channel app and look at radar, its raining at home. Oh well, says it will end soon and temp will shoot up, roads will be dry by the time I get there. 10% of any more rain. I'm about ready to leave work and the skies are darkening. Weather channel future radar says it will be fine. I walk out to my car, the skies were mostly blue 15 minutes before. The sun is gone and its a complete downpour. Before I get home I hit a spot with flash flood inducing rain. I get home, spend almost an hour drying and quick waxing my car. ITS STILL POURING RAIN AS I TYPE.
So yeah, only 10% chance of light showers, west of Tulsa today.
The toy dump truck(err, bed of it) was empty this morning. That's almost 2" of water.
Edited by SnakeEyes
You have just described the weather here for the whole summer. Even if the forecast says 0% chance of rain you cannot bet on it for more than a couple of hours. Amazing how the torrential downpours and storms pop up out of nowhere nearly every afternoon. I have given up on scraping the driveways back into shape until November because they have been washed out more times than I can count this summer.
Edited by waumo1
Cleaned and conditioned leather..... :cheers:
Today we had a 20% chance of rain.
This is why most weathercasters only live here a few years. They have to go into witness protection after that.
It better not rain saturday
Going up to cars and coffee
Ryan
Ryan
Not the Lingenfelter one right? That's a hell of a drive!
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
