All you need to know on page 1 post 8
Thanks for the info. This points me in the right direction but it won't work with the Silverado.
I looked through the connector pin list and nothing is listed for low beam headlight relay. This makes
sense for the Sierra as you only have a single bulb headlight and the high beam is turned on by moving the shutter in front of the bulb (according to the HID sticky thread).
I'm hoping someone has similar BCM pinout info for the Silverado.
This would be much easier if Helm would publish the 2015 service manuals soon. I'm guessing with the
8-speed transmission addition it will probably be 6 months until they get the manual out.
Anyone have the Silverado headlight wiring diagram out of the 2014 Helm manual?
Thanks again.
Edited by DanY
Thanks again.
I just did this mod with my 2014 Chevy Silverado in the same spots as it says to and the mod works great.
There are quite a few with Silverados in this thread that did it and worked just fine. Just use Spurshots pics as a guide and should work
Thanks Spurshot, followed your directions from Page 1 and works like a charm. Got fogs with high beam like it should have been from the factory. Isn't the idea of high beams to put out as much light as possible for your driving safety?
Thank you spurshot!
ok, I've read from page 1 to about page 16.
have decided to go 10~22 but my question is
I have 2015 Denali, and from what I read, 10~22
turns on the fogs with the parking lights..
I typically do not touch the light switch... its on
automatic, except to turn on the fogs. So will this
jump 10~22 "automatically" turn on the fogs when
the engine is started? I realize the Chevy has a
different headlight configuration and this is what
is throwing my logic that 10~22 will work...
any help or clarifing would be helpful. If this works
and I get the damn diode in, I'll have 9 diodes to
send out to anyone who wants one...
Foglights will come on when low beams come on. With DRL, no foglights. I have same jump 10-22 and keep my switch on auto. You wont have control of foglights but they will be on at all times with low and high beams.
Here's the circuit. BCM is between the dash switch and the fuse/main buss as I suspected.
instead of useig a diod what don't you just grond the wire coming from the fog light really befor going into the BCM then you can still turn them off with the hi beams on if you want to Edited by Rme2513
scratch that then they would be on all the time. There is not an actual switch in line it is done in the BCM
This was on the Duramax forum. I believe it is for a GMT 900. But the principles are likely applicable to a K2. Use this information cautiously.
"This is a write-up for how to make your low beams and/or fog lights stay on when you switch to high beams...This mod costs all of about $1 and should take no more then 15 minutes..its very very easy and use's the trucks own built in fuses and relays. Credit for this goes to Will from duramax diesels...i just made some additions and modifications..
All you need is a set of diodes that you can get from your local Radio Shack. The part number that I used was 1N4004. I have read that 4001,4002,4003 and 4004 will all work. These diodes come in a 2 pack and cost $.97.
You will do this mod under the hood at the fuse block on the drivers side of the truck. Make sure that the truck is off before reaching in there. You shouldn't need to unhook the batteries or anything like that.
On the bottom of the relays is the numbers for the different pins. You will be using the 85 pin for these mods. Also, on the bottom of the lid of the fuse block is a diagram showing the numbers of the pins along with which relay goes where. The 3 relays that are used are in the lower left hand corner of the fuse block
Hi-lows on at the same time.
You will need to connect the 85 pin of the low beams relay to the 85 pin on the hi beams relay. Make sure that the "bottle cap (or end with the stripe)" is going towards the hi beam relay. You can either wrap the wire around the metal pin or slide it into the hole that the pin goes into. Either will work.
Hi-fog on at the same time.
For some reason GM decided that when your high beams are on, your fog lights don't need to be(actually i believe this is a law) . Well I like my fog lights on adding more light. With the hi beams on adding a lot of light, then the fog lights on adding more light can't be a bad thing right?
To do this you will need to connect the 85 pin of the fog lights to the 85 pin of the hi beams. Make sure that the "bottle cap (or striped end)" is going towards the hi beam relay. Again you can either wrap the wire around the pin or push it into the hole that the pin goes into. If you are doing the lows plus the fogs it can be a little tight on the 85 pin of the hi beam pin. For this I wrapped one diode around the pin and the other got pushed into the hole with the pin(i pushed both into the slot...they fit you just need to push down hard on the relay) . You will still have control of your fog lights on low by switch but by doing this the fog lights will always be on with hi beams.
This Mod works perfectly with HID's as well as regular bulbs.
The pic shows how I have it wired. Sorry for the poor picture but hopefully the labels will help better explain things. the second pic is what the diode pack looks like from radioshack..its on the left
Do you have a picture of how the diodes look in the fuse box? I have figured out the underdash mod, but am looking for the hi-low combo as well. Thanks
On Jul 11 2014, when you originally posted this, I ordered some diodes the next day. Now its June 2nd 2015 and I just got the install done LMAO!!!.
Most expensive mod I have done to date, but that mostly because I dropped & broke my iPad Mini 3 LTE device while trying to look at your pictures from an inverted position. :)
I don't remember saying this was going to be cheap to do. The best mods are always expensive.smiley_quickdraw.gif
Edited by spurshot
I have the receipt dated July 22, 2014 and diodes sitting right in front of me. Haven't even broke them out of the package yet. How sad is that?
I was waiting for the headlight update, and it is much better driving at night now. Now I can't decide which way I want to go with it, so I am at a stalemate, or impass, or procrastination, or something like that?
I may get around to it someday?
