Seat cover for Dogs
Just bought my truck and have not let me dog ride in it yet. In my other car/truck I would just put a sheet over the seat but hair still got everywhere. I would like to keep as much hair as possible from getting all over the truck. I know it is a losing battle but do you guys suggest anything that helps catch the hair or any tips?
The hammock style dog covers seem to be the most popular.
Since we don't have kids, nor do I haul many people, I'm going to make a plywood platform in the back. I will fold up the seat and use a couple tiedowns to hold them up. Then put in a platform with a pad on top. It will have storage underneath for shotguns or whatever.
I have two Lab/Retrievers, all I use is an old sheet and a water proof dog cover… I find the new trucks have a much more pet friendly fabric, my last truck was a 2012 and the hair got stuck to everything. The dogs hair still gets everywhere, but it cleans off very easy…
I put some headwaters seat covers on my 14. Very nice product and Paul is an excellent guy to deal with. Went with them because Paul customer service reputation. Also, the wide range of add ons available.
why don't guys just pull up the rear seats? no way I would let my dogs pounce all over my seats...cover or not.
Once my dogs are up on the seat they don't move much, and if I pulled up the seat they couldn't reach to stick their heads out the window (a great joy for at least one of the dogs)… Plus with a Double cab, there isn't much room for them to sit or lay down with the seat up, the floor is not exactly flat…
I bought a furminator deshedding tool for my Vizsla and WOW the thing works wonders. They are pretty pricey but well worth it, she barely has any hair come off while riding in the truck. I will stick to using a bed sheet and just make sure she has gone through a couple rounds of the furminator.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
