6.2 Throttle Lag
  • Replies 30
I think this is a common issue in all the 2014+. I have it on the 4.3 also.
Sent from my SM-N900T using Tapatalk
I'm guessing that all that thing is doing is making 1/2 throttle appear to the engine as 3/4 throttle, etc......
Might work for you though.
I think the throttle response of the new 6.2 it's10 times better than the 07-13 6.2's, mine is anyway.
Ron, et al,
When I was trying to eliminate lag on my 2008 vmax, I discovered it was mainly a transmission downshift lag. To check this, try driving with the transmission in the manual shift mode. I think you'll be surprised. The problem with changing the downshift logic is that it will have a big impact on fuel economy.
Its quite possible most people are confusing throttle lag with TM or traction control, more so with the 6.2. My 5.3 on E85 with a caned tune with break the tires easily up to a 30 mph downshift on certain roads. If you running a 342 or 373 gear even with a rolling take off your going to spin the tires. Try turning off the TC.
I don't have personal experience with it in my own personal truck but I drove a 5.3 with that throttle booster installed the dealership was using them and it was definitely noticeable. I dunno if it tm or not but it just felt like to me the first 10% of throttle travel seems to not respond to much kinda like a dead man switch, always have to have your foot on it to do anything, the throttle booster worked but I think their kinda spendy for just that 1 function but was nice.
From the looks of this thing, it's simply an artificial advance on the throttle signal. Ie, it intercepts the signal, adds 10%, etc, and fires it off to the ecu/throttle body. So it's not eliminating any throttle lag, it's simply opening the throttle more for a certain gas pedal position than stock. Pretty pricy if that is all that it's doing, just push the gas pedal faster.
GM usually puts a dead spot at the bottle end to allow you to roll into throttle more, ie, help prevent lurching and smoking the tires from a stop when you hit the gas pedal.
For the actual throttle/acceleration lag, an ECU tune and transmission tune can easily fix it. A transmission tune helps the truck kick down more quickly, and the ECU tune helps in quite a few different ways, one of which is reducing the PE (power enrichment, ie, open loop fueling) cycle lag time when you go to wide open throttle.
The lag I experience is feeling like I have to push the pedal down about 3/4 of an inch before the throttle engages at all. From a dead stop its really bad compared to my other vehicles.
My 2014 GMC 6.2. The throttle lag is ridiculous, has anyone done anything to fix this problem. I am thinking of trying the sprint booster has anyone done this
https://www.sprintboosterusa.com/
Thanks
Ron
I have the sprint booster on mine..works great I highly recommend,
glad to here that i may have to try one, I found a guy that will do the ecm programing just waiting to here from him
and wheres a pic of the C10
Heres ours we just finished
How long have you been using the SprintBooster?
For what it does it's a bit pricey however if it truly makes the driving experience more enjoyable I would say its worth it!
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 960 Guests (See full list)
