heres my 14 sonoma red. sorry for the crappy pic just drop it off at the body shop after smashing a deer. 2.5 in rc with 285/70 17 mastercraft mxt
The Chevy version Deep Ruby Metallic. A few different shots to show how the color changes in various conditions. "ME LIKE IT A LOT"
It was the color that caught my eye any other truck I would have just drove by...
10506758_10152136084076525_7881201902165
That's the first truck I have seen with painted fender flares, looks perfect! Wish they came that way!
Sharp truck!
Smiller I agree I've seen a summit white with em painted but not a Sonoma truck, really sharp!!
Edited by jamin87ss
Sharp truck!
You can order some colours that way.
While it can be ordered isn't it dealer painted/installed? If it was a factory item I would be all over it as I have zero faith in a dealer painting them.
RPO code:
SF6 NEW! LPO, Body color wheel arch moldings
1 - Requires (GAN) Quicksilver Metallic, (GAZ) Summit White, (GBA) Onyx Black, (GBN) White Diamond Tricoat or (GCE) Sonoma Red Metallic.
GM accessories has part numbers for some of the colours, and a primer version for aftermarket painting of the colours they don't offer.
Front and Rears, Prime - Paint to Match 22943047
Front and Rears, Sonoma Red (GCE) 22943041
Front and Rears, White Diamond (GBN) 22943045
Front and Rears, Summit White (GAZ) 22943037
Front and Rears, Onyx Black 22943039
Front and Rears, Not Compatible with Splash Guards, Quicksilver (GAN) 22943043
They also have flares available: (by EGR, but through GM accessories)
Rugged Look Fender Flare Fits All Bed Lengths, Not Compatible with Splash Guards, Black, by EGR® 19303664
Bolt On Look Fender Flare Fits All Bed Lengths, Not Compatible with Splash Guards, Black, by EGR® 19303665
Edited by redwngr
Here is my 2014 Gmc SLT 6.2 Max trailer pkg., A few chrome acc. and 2" leveling kit
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
