37K on 2012 5.3L GMC Sierra
Never a big Mobil1 guy but then again my world has always been Valvolene products... I would think that any issue you have internally would not be subject to Mobil1 but more so toward the Seafoam in every tank. I can see a can once or twice a year for the injector cleaning but not every tank.
I only add Seafoam to a gas tank during my 6K oil change(s). Not everytime I get gas! :happysad:
So a can of Seafoam goes in 2 times a year...
Ahhh,,, Scratch my previous thought... But on that same thought, what is Seafoam for? With a properly maintained, non high mileage, non abuse engine, why use it at all? Just asking..
I still think it would be the culprit but my days of tearing engines down are way past me... With all the different detergents and additives in gas these days it could be that as well... I stand by my words of get a tune and get that AFM taken out!
Today's fuels are simply JUNK!
SeaFoam keeps any and all deposits down, off valves, keeps carbon from building on top of pistons/rings, etc...
They are, huh? I strongly disagree. if anything the top tier fuels are better then they ever have been. The refining methods and detergents used to keep the fuel systems clean has only improved over the years.
With the direct injected engines, the best fuel and oil will be necessary to keep the intake valves from carboning up. A catch can is also a wise investment.
Like others have posted, I can't see that Mobil 1 would be the problem here. Deactivated cylinders will likely cause oil usage due to the rings not being pressurized on the power stroke.
I've used Mobil 1 full syn. for many years & on my truck since new, because it has always placed among the top oils in wear tests. Now 240,000km (150,000 miles) on my 06 & still going good; little to no oil usage between changes & oil only gets changed when the monitor says so, which is usually at 12-14,000km......
The oil is not the problem. The AFM and the oil that goes thru the PCV line are. It is just that simple. I have had the AFM disabled on my 2013 5.3L since 240 miles on the odometer. I have had a PCV oil catch can on since 1190 miles on the odometer. Engine, since I drained the factory fill at 1190 miles, has gotten Schaeffer 9000 5w30 synthetic. I only use about 1/4 qt of oil in time it takes to get the OLM down to 10%, or roughly 7500 miles. And of that, all but 2 oz ends up in the PCV oil catch can. So the engine is only "using" about 2 oz of oil in 7500 miles.
The Schaeffer oil I use claims dexos1 spec, but is not on the "approved" list. That it is not on the approved list really never concerned me. I run oil sample analysis on my commercial stuff, and decided that the pickup needed to get one just to see how the oil is holding up. When it gets down to under 10% on the OLM, I will change the oil and send in a sample. Will post the results on the forum when they come back.
Mobil 1, Pennz Ultra and Platinum, Amsoil, and the list goes on, are all fine oils. They can't be blamed for what the nincompoops in Detroit decided to do to a perfectly fine motor. And don't go blaming fuel either, or ethanol. That is a red herring thrown up because of some folk's bias. The fuels are fine, just like the oils.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
