Transmission cooler
These 6L80/90 transmissions have low friction loss very low slip if any due to the clutch to clutch design. They run them hot for efficiency. Less friction, better mileage. Even the front drivers run 160-190 degrees.
The exception to this is the HD trucks and the GMT-900 and prior trucks. They are a constant flow (no thermal bypass preventing flow) through the radiator and aux if equipped. My 2012 ran no hotter than 170 in the summer and kept a consistent temp range of 120-150. Same for my 2015 HD. 120-150.
I hit 205 several times in 80-90 deg weather this summer without towing anything.
I've hit 220 with my 4.3l one time while towing. GM tech support told me not to worry up to 230, and in a thread I posted about this issue a guy posted a response from them where they said 270 is where the fluid is damaged.
The shop I bought it at told me there is no OEM cooler as you found, and that I should not add one.
The 2014 Sierra I was going to buy before it got sold out from under me listed an auxiliary trans cooler on the options, which was one of the reasons I wanted it.
I live in AZ and the summer is HOT, earlier this summer when towing my 23ft Toy Hauler up some decent grades my tranny temp would hit 250 on pretty much any long grade. If the grad was steep but short I would see about 220-230 regularly.
http://www.carcraft.com/techarticles/116_0308_transmission_cooler_basics/?__federated=1
While my temps are technically in range, they are at the top of the range. That's cruising with no load.
Most of those charts and articles from companies who make transmission coolers are based on 1980's vintage testing. Different transmissions, different fluid. A chart with a newer transmission and Dexron VI might be informative, but I've never seen one. They claim Dexron VI is twice as resistant to oxidation so that would really change those charts.
Yes, that's definitely hot enough you'd want to do something about it. As mentioned before, reprogramming the fans is the easiest, and if that's not enough an additional air-air cooler would help.
Something else that will help that's expensive, but there are a lot of other reasons you might want to do it anyway, is re-gearing. If a set of 4.10 gears lets you pull those hills in 3rd instead of 2nd gear, the transmission (as well as the engine) will tend to run much cooler.
I won't tune my truck only because the fact that it does run so HOT, the last thing I need is for there to be something wrong down the road and it not be covered because I tried to help my issue.
Based upon what? There's absolutely no advantage to running colder transmission fluid except worse mileage. You aren't going to hurt the transmission unless it gets a lot hotter than that for extended periods of time.
+1
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
