2014 Silverado air bag removal
I started a thread about color matching the emblem on the steering wheel. I think I'm just going to use plastidip. But, I would want to remove the airbag assembly so I don't get any overspray inside the truck. I can't find anywhere (even YouTube) on how to remove the airbag from the wheel.
Has anybody done this or know someone who has?
I know the gens before just had a hole or 2 where you can stick something in them to unhook the airbag, but I don't see anything like that on the 2014s. I've looked and felt all around for something and can't find anything. I'm scared to just pull it away from the wheel from either the top or bottom because my luck it will break a clip or something. I guess my last resort would be to go to the dealer and ask one of the techs, but I hope I won't have to do that.
Thanks
I understand your over spray concern. Have you thought about using a two liter bottle or milk jug cut down? Heck you could even use a cardboard box. Any thing thats about a foot long. Try it somewhere away from your truck first to see if you like it, its way easier then taking the airbag out.
Thanks for the idea. I ordered a small vinyl sample to try first and I couldn't get it how I wanted it so I guess I'll try plastidip next. If I could pop the emblem insert out I'd just use paint made for plastic, but it has a chrome trim that stick above the insert and I tried with a plastic razor blade and couldn't get it to work. I know plastidip can easily come off but I don't want to think about trying to go through the whole interior looking for overspray lol. Too bad the only place around here I found plastidip doesn't have glossifier so hopefully it won't look too flat.
Plasti dip over spray is hard to get off. It only peels of easy when there are multiple layers.
How many coats would you suggest? I wouldn't think it would be many just for a steering wheel emblem.
At least 2-3 coats. I like the little paint booth idea and I know my buddy did this to his mustang. Go thick with the first coat just dont get it runny. The more coats the easier it peels off.
Well I don't plan on peeling it off unless I screw up somehow. I've seen vids where somebody used plastidip and showing how good it last. I'm not too worried about it chipping since that's not a part of the wheel that your hand touches and it's not going to be in direct sunlight like the outside of the truck is.I may just do 3, maybe 4, and see how it looks. I may find some glossifier, do I add that last, or between a couple of the black coats? I may need to look that up to.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
