Rancho quicklift loaded
fuse36
Toyo makes a 295/55 all terrain
ok sweet
Sent from my iPhone 6
using Tapatalk
  • Replies 188
Thanks for the update and pics. How hard is it to adjust them? Do you just put it in and turn the red knob on the shock?
once shocks are installed at anytime u can adjust by clicking it from 1 to 9. Front wheels just turn in so u can reach the red dial. Very easy.
using Tapatalk
  • 1 month later...
Does Rancho make these specifically for the 2014's+? I could not find them on Rancho's website for the 14+. I really like the idea of the adjustable shocks. I have a Polaris RZR 900 with adj Fox shocks and cranking the dial on those makes a big difference in ride, which would be nice to have on a truck as well.
I notice on Ranchos site it states for steel control arms , will this work with the aluminum as well ?
yes I have aluminum. Works just fine
Update on rancho quicklift install and rs9000xl rear 14 silverado LTZ Max tow package. Once again nothing but positive results. Pulled my trailer all day. Around 4500 lbs. did not squat and drove amazing. The front end felt so tough and firm while pulling. No bouncing and rear is very strong now. I had the front set at 6 and rear at 5. I love the adjustable shocks. Great feature and can really tell the difference. This is night and day over a level kit. Obviously it cost more but if your someone that drives more than 10 miles a day and pulls a trailer every now and then I would definitely recommend this set up over a $65 leveling kit. Also my front came out to be 1/4 " higher in the front then the rc 2" leveling kit so I'm very pleased with that. I will post a few pics. We had bad weather today so not a lot of pics but can post more soon. Ask me any ?'s that I have not mentioned. attachicon.gifImageUploadedByTapatalk1417743463.800539.jpgattachicon.gifImageUploadedByTapatalk1417743477.672789.jpgattachicon.gifImageUploadedByTapatalk1417743487.327647.jpg
using Tapatalk
attachicon.gifImageUploadedByTapatalk1417743518.891322.jpgattachicon.gifImageUploadedByTapatalk1417743529.029767.jpgattachicon.gifImageUploadedByTapatalk1417743536.967936.jpg
using Tapatalk
attachicon.gifImageUploadedByTapatalk1417743553.626730.jpgattachicon.gifImageUploadedByTapatalk1417743564.497577.jpg
using Tapatalk
What are your fender measurements ??
The RS999297 is what the rancho web site said I needed too. I called tech support was told I need RS999198 for the rear and they are sold as a package on ebay as RS999901 front and RS999198 rear for $555.00 free shipping. Think this is what I will do. I also have aluminum upper and lower control arms Z71.
Has anyone on the front install had to remove the upper ball joint to intstall just wondering.
Found this on the rancho site the compression lenghts are different between the two.
I'am not raising the rear any.
RS999198
COMPRESSED LENGTH EXTENDED LENGTH TRAVEL LENGTH LOWER MOUNTING CODE UPPER MOUNTING CODE PARTS PACK 15.910 25.080 9.170 LS47 LS47 None
RS999297
COMPRESSED LENGTH EXTENDED LENGTH TRAVEL LENGTH LOWER MOUNTING CODE UPPER MOUNTING CODE PARTS PACK 18.625 30.500 11.875 LS47 LS47 None
from ground to bottom of fender is 38 3/4 front and rear. I have 305 50 20 toyo open country atII. I am going taller tire next time I now have the extra room.
Sent from my iPhone
using Tapatalk
RS999198
RS999297
RS 999297 is for the 6" lift. U do not want that if your doing quicklift in the front. It's a very tall shock. U want RS999198
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
yep after I read the specs on the ranchos knew the RS999297 had to be for a lifted rear just letting others know because on there web site if you type in your vehicel the only number for the rear is RS 999297.
Do you know if they had to take the upper ball joint aloose for your install.
Thanks
    juggernautusa
    juggernautusa
  • Who's Online   4 Members, 0 Anonymous, 753 Guests (See full list)
