Close Encounters
General Lee 01
So, I'm sitting here at the computer last night, when I hear something messing around with the trash cans.
So I'm thinking "oh Sh*t, somebody's trying to break in!", so I run to the back door, and hit the flood lights over the backyard. (Hey, if I get attacked, I know gow to scream, yell and punch and Kick, and plus I'll be able to give a description to the police).
Well,I look out there, and I see nobody, but I notice the trash can lids had been taken off. So I look closer to the cans, and  3 seconds later a racoon poked his head out of the trash can and looked  straight at me, a couple seconds later, a 2nd racoon popped his head out of the other can.
I thought it was so funny, the way their heads stuck out the trash cans. It was "cute". :)
This was the first time I'd seen a Racoon too, so I was excited, I stood there for 30 minutes and watched them eat up the garbage, didn't bother to shoo em off or anything.   :nono:
Now that they know you like them, you'll see them all the time...  They are pests and will keep coming back until you get rid of them.
You are right, they are kinda cute..................
.............till they try to rip your face off. :nono:  :)
RACCOONS ARENT CUTE
We had em living in our rafters last yr.  It was a PITA.  WE actually caught one with a trap (it was a big one, mean too it was barking after it got caught).
We had exterminators come out.  The fixed the rafters sealed em up put metals things over vents and such.
Later last summer the neighbor got em and they destroyed their attic
:nono:
They also can carry rabies.  If you are a gardener, it won't take long to really dislike them.  They know the very day that corn is ready to pick and they get it the night before!  :nono:
Back in the mid-90's, our area flooded in all of the lower areas.
A close friend and I took a 14 ft "John" boat down the "roads" of the hunting club.  On a floating log, we trapped a flying squirrel.  On a large overturned stump, we captured a raccoon.  That was one mean S.O.B.  Both of us were actually timid about handling the cage.  Boy was he pi$$ed.  We set him free on dry ground about 300 yards from where he was trapped.  He tried to get into the boat and "get" at us.  The oars "convinced" him to leave us alone.
Racoons are no big deal compared to skunks. We've had those things real bad around here the last couple of months. We had two of them living in an old shop by my house and it wasn't pretty getting them out of there. :nono:
Its a lose-lose situation trying to get rid of a skunk.  :)
Yeah, they are pests, but if you think I'm gonna shoot them or try to kill them you are mistaking.   :nono:
I will not shoot at anything That has 4 legs (excluding mice), I'd rather sit back and enjoy watching them do their stuff, rather than point a gun at them. :)
Just have plenty of lemon juice on hand.
Never had an encounter with a racoon but have once ran over a dead skunk with our 18ft PTO shredder
Took out some sort of black snake once with a 61" Scag commercial tractor in a field a number of years back.  That was fun :D
I chased a frog accross the back yard with the tiller one time.....
.....Like I said one time.
My a$$ still hurts from that beating.
Stupid little sucker got away too.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
