Tuner for 6.2L 8 speed 2015 GMC Sierra Denali
Need help getting a tuner for my truck from either bully dog or diablo but I am not sure if one will work on the new trucks anyone know or can help?
also where does everyone mount their tuners on their 2014+ GM trucks
I am sure no one has a tuner out yet, I would be contacting black bear and other efi tuners.
Might see who is doing Corvette tunes as they have had the drive train a lot longer.
The torque management was a joke on the 8-speed I drove the other day, ecm pulled all power on shifts, fell flat on its face, with as quick as the 8-speed can shift it should simply blip the throttle as it rips a shift, with GREAT tuning I think great things can happen.
Letting a tuner program the new trans scares me.
Go with the autocal and blackbearperformance.com
Ryan
Ryan
Im hoping bully dog has something.. the trucks fast enough as is i just wanna lift the sped limiter cause going 98 only just kills me
Subscribed.
Way back when I had my 2003 Avalanche, I was passing a long line of slow cars when I hit 103. It's the worst feeling to have no more power and have it cut out in that situation.
I would be surprised if anyone has the ability yet, while the Vette came out first with the 8sp those cars have only been on the lots for maybe a month or so now. Usually once HP Tuners or EFI live breaks the code then everyone else will be able to access the code as well.
  • 1 year later...
I'm in the market for a bully dog on my 2014 to firm up my shifts and raise speed limiter ONLY. My 6.2L has plenty of power and if I want more I plan on adding a supercharger but the way my 6spd shifts is like a grandma between gears. with my handicap conversion i'm unable to access manual mode or tow/haul mode because they remove the shifter stalk to do the conversion. I shift with a touchscreen.
anyone have experience with a bully dog on a '14?
If all you want is the abilty to remove the speed limiter then most tuners are able to do that. Mine is Diablo tuned and while I hardly notice any difference over stock, I am able to go over 98. I hit 121 in the UP last week and it was still pulling very hard.
actually shift quickness/firmness is my main concern. rarely do I get the change to top end my truck but those granny sloppy shifts bug me
Your truck is a 6 speed. Most tuners can tune that trans. I was responding to the OP as we have 15s with the 8 speed.
You will wish you didn't do that when the driveshaft exits the truck. I am all for going fast but the driveshafts in these trucks are known for flying out, good way to get killed. YouTube is your friend if you don't believe me. Not busting your balls for speeding at all, I love to rip, I just know the limits of the driveshaft on these trucks and you don't want to have the rear end of the truck catapult 6ft in the air when doing 120mph, it will kill you
Youtube is your friend...i have seen videos of many many gm trucks doing well over 130+ for extended periods of time. I have been over my 98 speed limiter twice, ever. Once to make sure it was turned off, hit 104 and then last weekend. The new 6.2 is so fast it hits these speeds far quicker then you would think. I hit that passing 2 spaced out cars downhill. There isn't a doubt in my mind the 8 speed 6.2 can do 140+ but I wont do those speeds that long.
Rockout, I don't give 2shits if you roll it 12 times or not, was just giving you a heads up. I just posted a video of me doing 111mph in a 6.2 the other day, I love to go fast, just don't like the driveshaft results from doing so.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
