6.2 8 speed
Been running Dmax's for about 10 years.
Do you miss the torque of the Duramax? Once you get more miles on your 6.2 / 8-speed, I would like to hear your comparisons of the 6.2 vs 2011 - 2015 LML Duramax.
It's still less than 200 miles, so I haven't been to hard on it and I haven't had a trailer hooked up.
I'm sure I'll notice the torque difference when towing. I tried to order an NHT 6.2/8speed, but didn't want to wait for it to be built mid Jan - and probably not delivered til end Jan, as we intend to be south by then.
I'll post comparison feedback when I get some more miles on it.
It already looks like the 6.2/8sp will get better mileage doing daily driver duties.
I found a few while shopping, want me to see if i can find them again?
What state do you live in?? I am in mass and I can't find an SLT with max towing anywhere
I just want to know if the transmission seems less confused then the anemic 6 speeds they are still putting in ? Knows when to shift, dosent fluctulate , dosent just kick you in the back , etc.
The programming seems excellent so far. Shifts are fast and smooth. Smooth enough that it is near impossible to keep track of what gear it is in.
IM sure he will a dmax has what double the torque. You may not notice it as much under normal driving but in towing he sure will. I have owned two powerstrokes in the middle of a chevy and a ford before my current chevy. Although the chevys were both 5.3s with 3.73 and the ford an ego with 3.73s nothing is close to a diesel. But I got out of the diesel game, i could get buy with a half ton and save thousands doing it
IM sure he will a dmax has what double the torque. You may notice it as much under normal driving but in towing he sure will. I have owned two powerstrokes in the middle of a chevy and not a ford before my current chevy. Although the chevys were both 5.3s with 3.73 and the ford an ego with 3.73s nothing is close to a diesel. But I got out of the diesel game, i could get buy with a half ton and save thousands doing it
And the diesel makes it's max torque a 1600rpm. It doesn't have to downshift to pass/merge/etc even when pulling the trailer.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
