That was the surprise I was holding back for a couple weeks lol
Sent from my SM-N920V using Tapatalk
Well it definitely surprised me. Can't wait to see it.
I'm surprised with the BDS bad luck. My uncle and two of my buddies run them and said install was great. Although those all were on torsion bar gmt 800 trucks. Good luck, can't wait to see it!
I've always heard of BDS being a top player but when the crossmember holes don't line up and you gotta start reaming holes you start questioning things lol
Oh jesus... yeah that's not good at all. You don't think your frame got twisted the slightest bit in your accident do you?
I slid into the ditch on the side, I don't think it affected the frame but who knows. You may be onto something though
Well for your sake I hope I'm not. I hope it is just a BDS quality control issue.
I got it to fit, just waiting on a replacement part because I broke something out of my own stupidity trying to get shit done too quick hah
If I had a dollar for each time I've said that...
You'd have $2?
Ryan B.
You'd have $2?
Ryan B.
I don't even have that right now [emoji23] [emoji23]
After spending $50 for parking at the Cubs game Friday my wallet is empty also
Is it finished? Man, I love BDS. Very good lift on my old truck lol
Yeah she's all done. Setting at the dealer right now getting my fuel issue looked at from when I had to drop the tank to install the lift springs. Keeps tripping the shut off, seems like a vent issue honestly
Man, thats looks wicked! How you liking your RTs? also, what wheels did you go with?
Tires are awesome so far. Slight hum nut not much worse than my KO2's. I went with the Moto Metal MO970 wheels, -24mm offset. Thinking about switching to the Moto Metal MO962 wheels since I am scraping. The new ones would be 0mm offset
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
