Back up camera
SlavO
Not coming on when i put into reverse ?? Turn the truck off and tried it again nothing. The reverse screen isnt coming on at all. Any ideas?
How fast are shifting into reverse after startup? Let the gauges do their full sweep before you try to start moving. Let's things warm up a few seconds.
If the screen goes blank, there was a "calibration" software update to fix it. Not sure if the calibration helped if screen doesn't try to change to camera from your standard use (radio/nav/etc) screen.
Make sure the update for the black screen has been done. As said give the truck about 10-15 seconds before you shift into gear. There are prob 10 or more modules that have to boot up when you start the truck up.
Hi SlavO,
Please let us know if this issue returns with your back up camera. We're unable to provide technical advice, but we'd be happy to look further into your concern. Also if you ever have questions we're here to help!
Kristen A.
GM Customer Care
Thanks for all the help. I was driving for 30 min then put it into reverse and nothing happened. . Should have said that in my original post... knock on wood it has not happened again. ... when i start the truck its 99% parked where i just put it into drive and go.
I would still go in and have the update done for the nav screen going black. It addressed several other issues as well.
I have no issues with it now.. It does however, look like they extended the time it stays on once I shift out of reverse.
Not that is bad it helps find the line in parking spots ha ha.
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 409 Guests (See full list)
