Just picked up 2 weeks ago. i had it debadged, tinted and a 3M clear bra just done. Next week I am installing RC 2.5" Leveling Kit!! Cant wait....
Summit white Anzo tail lights.
Here's the video of me creating a masterpiece.
Sent from my LG-H918 using Tapatalk
the day i brought it home from the dealer with 45 miles
in my driveway with the z71 grill now covering the once vulnerable tranny cooler and the sidesteps.
I doubt i'll be doing much else to it, maybe a bug deflector (when i can find one already in white) and probably tint the front windows. Other than that, im sure it will stay just the way it is. On my d'max, a bug deflector was the only thing not original on the truck.
Sent from my SAMSUNG-SM-G920A using Tapatalk
juscuzram, I like your grill and white bowtie. I just ordered a white grill bowtie from eBay last night. Was the install a pain? Anything I should know.
Thanks! That's actually just a vinyl overlay. I'm looking at the white bowties on eBay, though. Let me know how you like them. The vinyl was on there when I bought it, but I'm probably going to redo it, because it's not perfect and I'm OCD haha.
i got the 2016 of that same truck... wonder what they changed~
i like your bass eating a frog pic man!!!.... i'm a bass fisher myself!
No more 20/17 combo. 17s all round now83982a5056ae34ee63c4e198dddf47c1.jpg
Just lifted her
Whites sharp when it's done right and all cleaned up...nice truck!
Thanks!
alt="be72a0d668b39631ff675fad0301d7dd.jpg">
Sent from my iPhone using Tapatalk[/quote
Lift?
2.5" front/ 3" rear block. 285/60-20 duratracs
Nice!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
