Someone say black?
10th vehicle in a row I've bought black... Every time I regret it though Haha!
"I swear my next truck will not be black. Ooh look! New Z71 Black Edition!" Damn!
i actually put the black emblems on myself to get rid of all the chrome I could.
  • Like 4
That truck looks perfect! What's the specs on it?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Someone say black?
Edit
Rough Country +2.5 level up front and +1 block in back.
20x10 -24 xd820 wheels.
285/55r20 Cooper At3 tires.
12" kickback flaps.
Black vinyl wrapped all chrome.
PPF over vinyl and full front end.
Full Debadge.
5% tint over  factory rear tint.
30% front tint.
Vinyl smoked rear lights.
Vanquish Auto LED's.
BakFlip HD Tonneau.
Planning on smoking the front amber signals as they stand out too much to me.
Also, going to do a muffler delete to give it a little more rumble.
Edited by hutch08
12" kickback flaps.
Full Debadge.
30% front tint.
BakFlip HD Tonneau.
Nice job on the build. Have you thought about clearing the amber then smoking it?
No doubt that would probably look better... but I'm not about to pull the headlights apart.
Too much effort for the end result haha, smoking them with film should cut down on how much they stand out.
2016 5.3l Texas Edition, 2 inch lowering shackles, 22x9 1/2 black Gima Paradox w 305/45/22 tires. Denali grille, wiring harness to keep drl on with turn signal. Lund Trifold tonneau cover.
Edited by deputy
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
