Finally washed mine today. Weather has been crazy and getting an additional pollen season. Was covered in pollen before I could even get it dry. Wasn't really feeling up to washing it since I got in a little fender bender a couple weeks ago, but wanted to see how bad the damage really was. 2 lanes turning left and the girl in the lane to the left of me decided to go straight instead of left, she was in the left turn only lane. T-boned my left rear, then lied to the officer and said I turned down into her. Now it's a he said, she said and we both get dinged on our insurance...d84c0ff0cbdeea4a8c2a8a3ffae4f9de.jpg45dc86ad4a8cbf111c3b142dc72cb442.jpg
Sent from my Pixel using Tapatalk
I don’t understand how people can suck at driving then lie about it.
No witnesses?? I’d say it’s time for a dashcam! Sorry about your truck
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
Rush hour traffic in Atlanta getting on the freeway, any witness was gone 5 seconds later. Damage is on the front of her car and the side of mine, she says I turned into her. Physically no way that can happen, can only hope the adjuster can prove it. Trying to get traffic cam footage or statement from fire rescue unit as to the location of the vehicles before they had us move out of traffic, but officer hasn't called me back. Adjuster said all that has to go through the officer, so I doubt it'll get anywhere.
Good luck buddy
23 hours ago, Bowtieguy17 said:
Here’s the latest pics of my 2017 Silverado.  Here is a list of the aftermarket mods I put on:
-K&N CAI, Diablo Predator 2, Dual Magna-flo exhaust, 4” Ready Lift lift kit, OR pocket flare fender, tow mirrors, 20 x 12 Helo wheels with 33’s.
Thinking of maybe putting mud flaps to protect the paint. Any idea? I am limited in room due to some rubbing if I put anything in the well.
I just put on Weathertech mud flaps a month ago, i really like them, and very simply to install...I even used a little clear 3m vinyl around the edges to protect the paint...the biggest pain was working around the rear tire...that took more time than that actual install...I don't have clearance issues like you might, but they don't take up too much room...might be able to work?  I would say that for you, I would recommend removing your rear tires for install (regardless which ones you go with).
I only go off roading pretty much when i go hunting, so limited...but if my truck was used for heavier off roading (or larger tires like you) I would probably opt for these...they were recommended to me on this site, I just don't off road enough to justify, but they look SOLID!
https://youtu.be/zS7HHhT_i68
Edited by spenpet
So I already have Chevy’s splash guards installed on my truck. I think those fender flares are nice but I would say they won’t fit on mine due to the splash guards and how they’re shaped/Installed. dc4c41a1c065fc2fb4d9faf9e5608a7c.jpg
you would have to remove the factor splash guards...its either one or the other...not both...
I figured as much. I’m sure there could be some engineering to installed the flares then the splash guards but not looking to do that..... at least not right now.
I can't tell 100% by the pic...but if you have the painted factory mud guards...I bet you could sell them here and get the more aggressive flaps if that is something you would want...again, not knowing how much you off road, it might not be worth it...as much as i do, the weathertechs have made a huge improvement for me...and i would imagine the factory ones are comparable coverage as the weathertechs...
Thanks buddy. Appreciate it!
Day I bought it (6/2016)
Today (5/2018)
  • Like 3
Today (5/2018)
How much did the black bumper cost you? if you don’t mind me asking.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
