Rancho or Bilstein
just to be sure, with these 5100's, it leaves the rear factory height and only raises the front 1.8" right? and does anything else need to be done as far as the suspension angles and everything else goes in relations to it being raised 1.8"s up front?
Yes, back stays same and front can be raised from 0 to 1.8". Someone else may need to answer the second part, but I think the front will need to have alignment checked after raising. I have to find someone to install them for me and plan to ask.
  • Replies 143
My rancho quicklift is over 2" of lift and love the rs9000xl in the rear. The best shocks I've ever owned. Also love the adjustable ride. Really makes a difference
Sent from my iPhone 6
using Tapatalk
I just installed my Rancho Quicklift loaded last night, it was a piece of cake. I took it to the alignment shop this morning and anyone asking if they should align it after any type of lift I would say YES! He said the camber and caster wasn't too far off but the toe IN was off by 3/8-1/2! Also, it rides much better than the factory Z71 Ranchos.
Will you guys post pics of the ranchos and the Bilsteins?
Also what height setting do you have them on? I read that height adjusted shocks rode pretty stuff with the spring seat in the top position. Which is what I would be going with the Bilsteins. But rancho offers a little over 2" of lift? More like 2.25?
I have the ranchos. Love them. If u set the front and rear to 3 that's oem setting. So if u go to 1 it's really soft not stiff at all. I leave front at 6. And change rear as needed. Here are rancho 4 top settings.
Rancho
RS999901 quicklift
RS999297 rear shocks
Highway front 6 rear 3
Sport front 8 rear 6
Tow/haul front 6 rear 8
Off road front 4 rear 4
Sent from my iPhone
using Tapatalk
Looks great! Lifted the front 2"? Ride is better than stock?
The one thing i don't get is that loaded strut is available for the 2014 chevy but not the GMC. Though i read it should fit.
I have a question/clarification. The rancho comes with new springs and the Billies re-use the stock springs, right? A spring compressor would be required to change the stock springs over to the Bilsteins? Is that correct?
I believe so, it's not recommended to compress the spring without a compressor. I know the Ranchos come with springs and the Bilstein's use the factory ones.
I think mine rides better than stock with the Rancho Quicklift and that's with some load range E tires at 50 lbs. too.
I didn't realize the quicklift loaded just had a single higher spring seat that wasn't adjustable like the Bilstein 5100.
There are also pro-comp ride height adjustable which is basically a new shock with a collar that you can flip over for 2.5-2.75" of lift.
I'm eager to see the 1.8" the bilstein adds. I currently sit at 36.5" in the front & 39.5 in the rear. 1.8" Would net me at 38.3 and leave roughly an inch of rake.
attachicon.gifImageUploadedByTapatalk1420514245.499834.jpgattachicon.gifImageUploadedByTapatalk1420514261.490624.jpg
Sent from my iPhone
using Tapatalk
How high is it sitting in the front after the rancho quick lift?
i bought truck brand new from the dealer with 2" rc leveling kit changed it out with rancho quicklift and now sits about 1/2" higher and rides much better
Sent from my iPhone
using Tapatalk
Thanks for the response, I currently have the 2" RC on mine and it sits at 38" in the front so, I'm guessing yours is sitting at about 38 1/2" in the front then, I've been thinking of removing the RC, and going with either the rancho quick lift or the bilstein, (I'm leaning towards the ranchos for the extra bit of lift)
Guys - I have a 2in level in the front end. If I get the bilstein shocks I can keep the level - and just keep the shock adjusted to the factory setting?
Or should I remove the 2in level and adjust the shock longer? I'm guessing it would ride better keeping the 2in level in place and shock at factory height.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
