Rancho or Bilstein
With the rancho coil over 2 inch lift do the ball joints stay within limits I talked to rancho tech about this and they said the ball joints would be in limits. I looked for the rear shocks Rs9000xl adjustable on ranchos site and the part # was RS999297 but rancho tech said I need RS999198. Just wondering what part # have been used.
RS 999297 is for 6" lift. U want RS999198 for level /quicklift.
Sent from my iPhone
using Tapatalk
  • Replies 143
Guys, what's all involved with installing the front shocks? Are you guys doing this yourself? can you provide some details...
Hey GMC, When I order the rancho coilovers RS999901 going to do install myself. Should be easy if you have done this kind of work before. My only question would be do you have to knock the upper ball joint loose and tire rod end aloose. I don't like having to do that especially on aluminum control arms. Never dealt with nothing but cast iron. Trying to find an install video on the net but haven't yet atleast not for 2014 gmc or chevy. Looked for install instruction on ranchos site but no luck. Maybe someone who has installed themselves will help us out.
No, you don't have to remove the ball joint, it's really easy to swap these out if you have the tools. Here are the steps.
-jack the truck up and put on a stand
-remove the wheel
-loosen the stabilizer bar bolt
-remove upper strut nuts, 3
-remove lower strut bolts, 2
-take out the strut and replace with the new one and put bolts/nuts back on
-put stabilizer bar bolt back in
-put wheel back on
-lower truck
-have 6 beers
-repeat on other side
-have 12 beers because you are done :)
Little update, I have all 4 ranchos installed.
It's a large Improvenent over the level kit alone.
One thing I noticed was my rear end jumped and banged hard with the extra 1 inch block before. The new rancho rears solved the issue. I keep them all on the softest ride setting ( cranked left )
And they are not quite as good as stock. But for 2 inches of lift it is a much better option. The level was a terrible ride. I recommend them.
My next plan is 3 inch body lift and 35s
-remove the wheel
-loosen the torsion bar bolt
-put torsion bar bolt back in
-put wheel back on
-lower truck
-have 6 beers
-repeat oter side
Thanks pt1911 about like I thought it should be. Do you like the ride better than the stock ranchos and what ride settings do you like the best. I like a soft ride the stock ranchos are to stiff in the front for me.
bubaloo1983 Do the rancho coil overs not ride any better that than the stock ranchos
AJUSA.COM has all 4 Bilstein shocks for 335.04. Just found them. Think that is the cheapest and free shipping.
That's cheap! I spent 413$ shipping included at suspensionconnection. Get home the two front 5100 struts are in, the rear shocks aren't anywhere to be found apparently. I emailed them.
Yeah mine rides a lot better than stock and that is also with load range E tires at 50 psi. I'm running them on setting 5 or 6......can't remember.
-remove the wheel
-put wheel back on
-lower truck
-have 6 beers
-repeat oter side
Torsion bar bolt? What are you talkin about? These trucks don't have torsion bars.
Ha! Good catch! I meant stabilizer bar.........too many beers for me when I posted maybe. Lol
Turns out the rear 5100s are on backorder till end of Febuary Should i cancel those two and look elsewhere? They didn't list as backordered is what bothers me. They listed as "ships monday"
ebay has them. Better price also
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
