Rancho or Bilstein
Bilstein's it is Ii found them for $383 shipped front and rear.
Please post pics before / after install.
I am interested to know the lift gained from these.
  • Replies 143
Having had a few sets of Bilsteins, including 5100 height adjustables in my 2008, and having one set of Rancho (OEM) shocks, I would go with the Bilsteins. No comparison. The Bilsteins have more sophisticated damping curves and much better ride quality.
I haven't had the Quick Lift Loaded adjustable damping shocks. Someone said they liked them.
Just an FYI the real Rancho shocks are nothing like factory ones. The factory ones are a massed produced shock with a Rancho sticker on them, probably mostly for marketing purposes. It's like the factory Toyota Bilsteins........if people bought those through Bilstein I don't think there would be many people on here praising them. :)
I don't know anything about Toyota OEM Bilsteins. Just the Bilsteins I bought and installed. I qualified my experience with both brands so the OP can weigh the information.
Post up the lowest price you guys find. Santa is going too order a set soon.
I only see part numbers for the rears on bilsteins website. My truck is 4wd with 6.2L maybe that is why....i did a search for 24-238304 and that part number doesn't exist. Can anyone shed some light??
If you want 2" of front lift instead of 1.8", put another couple psi in the front tires...or maybe get rid of those LED bulbs you put in. I hear LED is heavy. smiley_quickdraw.gif
I ordered a set of 5100's (front and rear) from Allshocks.com for $385.80 with free shipping and no taxes to Texas. I was interested in the 4600's and a recommendation between 5100 and 4600/HD since I am not going to lift my truck. In this particular case, the lowest ride height setting of the 5100 series front shocks will keep the truck at stock ride height, and will work fine for what I am doing, so what they recommend depends more on my timeframe than anything else. Bilstein does not currently have an ETA on the 4600/HD front shocks, and they guess that it will be several months before the HD fronts are released for sale. Though HD's would be the ideal choice for what I am using the truck for, the lack of availability is a problem. So they recommend the 5100 series shocks for both the front and the rear.
Allshocks.com also told me that the 4600/HD rear shocks and 5100 front shocks were on backorder from Bilstein since they shut down for the holidays. I placed an order anyway...I received another email today that their order came in yesterday afternoon and have already shipped them!
So, for those of you who are waiting for product, Allshocks.com has 5100's in stock, $385.80 complete front and rear, no shipping, no taxes (check your local state on their web page).
Part Numbers are:
Front 24-238304
Rear 33-238319
just to be sure, with these 5100's, it leaves the rear factory height and only raises the front 1.8" right? and does anything else need to be done as far as the suspension angles and everything else goes in relations to it being raised 1.8"s up front?
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
