Rancho or Bilstein
I would probably remove the spacer and use the shock to lift the front end. As that's what it's designed for. I did read that putting these shocks at their max ride height makes them ride a little rough but I've only read that once.
I don't know that I would use the spacer with that shock. Sort of defeats the purpose of getting the shock in the first place. Less your just looking for more lift.
  • Replies 143
If the max height makes it ride as rough or more as stock why not just leave the spacer and use bilsteins? I replaced my rear shocks with the old bilsteins and like the difference
Rancho quicklift loaded all day. Best shock ever.
Sent from my iPhone
using Tapatalk
anyone have any thoughts on this? I have a 2 inch level, and the front rides like crap. I wanted the rancho but it doesn't apparently lift the z71. so thinking of leaving the spacer and rocking the bilstein shock with it to keep the level. would this work?
I'm pretty positive the rancho will lift a z71
im really thinking it will too, just a bit worried to spend the dough and then it not. ive found a couple reviews online of people doing it with old gen pre 2013 trucks but I dunno how much the front ends are the same.
Rancho offers a 90 free ride offer
http://www.gorancho.com/warranty-guarantee/
Try qualifying Rancho products* for 90 days. We guarantee you’ll experience the Rancho performance difference! If, for any reason, the qualifying products* don’t live up to your expectations within the first 90 days, return the products and we will refund your original product’s purchase price (which shall not exceed the manufacturer’s suggested retail price), plus labor (not to exceed $50 per pair)
perfect thanks. well ill probably take the plunge then and give it a go. Im surprised no one else has tried this on the 14 z71 ( at least that I know of )
Which ranchos? The quick lifts loaded will work on the z71 as will the 7000mt. I know it says other wise but other than shocks I've yet to see an apparent difference in suspension of the z71 than the SLE stock.
Fuse has quicklift loaded on his.
I have a 2014 sierra slt z71 crew cab with a standard box. If I installed the bilsteins with 0" lift in the front what kind of ride difference should i expect? A little smoother than stock?
There are a number of OEM shocks. If you have the factory Rancho shocks, I'd say you'll see a pretty significant improvement in the ride quality. It'll be softer. I don't know about the Z71 46mm gas shock.
So as far as height on lift is concerned, I have the sle all terrain and want to put a 33 on the stock 20s. Bilstein only raising the truck 1.8 isn't enough IMO. A quick lift loaded strut by ran oh claims no lift to the z71 trucks however that makes little to no sense to me. Either way which would be the best option in getting a level and keeping the uca within reason to fit the rubbers?
Local shop that did my wheels/tires put a rc 3.5 lift/level kit on my truck, rides pretty harsh over speed bumps, will these shocks solve that issue, or are they not compatible with the 3½ kit?
Where did you read the Rancho claims NO lift on a Z71? All I can see is that it says on their web site it levels and lifts late model vehicles. I installed them and it lifted it a lot. The front and rear wheelwells are exactly the same now.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
