OkK still Ned some help. I installed the upfitter switch.  All exciting switches work. AUX 1-4 light up when toggled.  I went to the junction box and located pins ,4,14, and 20.  I installed a fuse in slot 22 for upfitter switch 1 and I go nothing at the junction box. I tried both positive and negative with the test light on pin #1. What am I missing? Should I get some indication with a test light?
You likely don’t have the wiring between the switch (S48A) and the junction block (X61A) and are probably also missing the wiring between the X61A and the Underhood fuse box (X50A). You can easily bypass the X61A altogether and run 4 wires from the output pins on the S48A straight to the X50A passing through the firewall boot.
If you have the provisions for Upfitter relays (pins in the X50A) than you should be good to go after you connect the switch to the X50A.
Are there directions for any of this? I've been reading through this, and am trying to figure it out although admittedly this is my first stab at anything like this. I seem to have the pins in the junction box, but beyond that I've got no idea what else there is to this, outside needing the new upfitter switches.
After reading through this thread numerous times, I put the following together to help me understand what was needed for a factory-like install on my 2019 3500HD.  Note that the Body Builder Manual referenced below MAY NOT APPLY TO YOUR VEHICLE.  However, many of the posts in this thread from owners of different 2014-2018 1500's and 2015-2019 HD's suggest the Aux switch circuits are nearly the same if not identical across these models and years.  The information is provided for USE AT YOUR OWN DISCRETION.
Wiring Schematic1,2
Trigger
Trigger
Output
Output3
S48A
X61A
X61A
X50A
X50A
X61A
X61A
Aux 14,5
X1 - 12
X5 - 10
X1 - 21
X3 - M5
X3 - M7
X1 - 16
X76 - 20
Aux 24,5
X1 - 13
X5 - 17
X1 - 34
X3 - F3
X4 - G2
X1 - 31
X76 - 14
Aux 34,5
X1 - 11
X5 - 11
X1 - 30
X4 - L6
X4 - K5
X1 - 35
X76 - 4
Aux 44,5
X1 - 10
X5 - 23
X1 - 38
X4 - L1
X4 - K2
X1 - 48
X76 - 1
Lead
13575783
19301767
19301767
19301767
19301761
19301761
13575832
1 See GM Upfitter Bulletin #110L, Figure 11
2 See GM Upfitter Body Builder Manual, 5-137-140, 5-170-171, 5-178-179, 5-654
3 See GM Upfitter Bulletin #115f
4 Trigger colors (Body Builder Manual) – Aux 1, RD/WH; Aux 2, YE/WH; Aux 3, GN/GY; Aux 4, WH/BU
5 Output colors (Body Builder Manual) – Aux 1, BU; Aux 2, GY/BK; Aux 3, L-YE/BN; Aux 4, RD/GN
6 Connector X7 needs to be purchased as part number 19328970 as per Bulletin 115f
A factory-like install can be accomplished by purchasing the GM "Leads", with the part numbers listed above.  One end of the wire will have a terminal that will go into the connector, the other end will be a pigtail that will be connected to the lead from the other connector, or may require you to lengthen the connection in order to reach the other Lead.  One advantage of the factory install is that you will have flexibility with how the switches operate as per Bulletin 110f by rearranging fuses in the X50A block. Note that the colors listed above are not the actual color of the leads, they are just what the colors the wires would be if the Aux switches were installed from the factory, and I note them here for easier reference when reading the pages listed in the Body Builder Manual; they are also noted in posts earlier in this thread.  Note that as per Bulletin 115f, the X61A junction block X7 connector will not be installed, you will need to purchase it as part number 19328970.
Here is an example build for Aux 1.  This assumes you have a switch panel and the correct X50A fuse block with factory relays and fuses.
1)  Insert the terminal end of lead 13575783 in to the S48A switch connector X1 in position 12.
2)  Insert the terminal end of lead 19301767 in to the X61A junction block connector X5 in position 10.
3)  Route the above wires behind the dash and connect the pigtail ends together with a butt splice or other connection method.  If the pigtails do not reach, lengthen one of the leads with 20 gauge wire so they do reach.
4)  Insert the terminal end of lead 19301767 in to the X61A junction block connector X1 in position 21.
5)  Insert the terminal end of lead 19301767 in to the X50A fuse block connector X3 in position M5.
6)  Route the above wires through the firewall and connect the pigtail ends together with a butt splice or other connection method.  If the pigtails do not reach, lengthen one of the leads with 20 gauge wire so they do reach.
7)  Insert the terminal end of lead 19301761 in to the X50A fuse block connector X3 in position M7.
8)  Insert the terminal end of lead 19301761 in to the X61A junction block connector X1 in position 16.
9)  Route the above wires through the firewall and connect the pigtail ends together with a butt splice or other connection method.  If the pigtails do not reach, lengthen one of the leads with 14 gauge wire so they do reach.
10)  Insert the terminal end of lead 13575832 in to the X61A junction block connector X7 in position 20.
You now have output on a 30 amp circuit when Aux 1 is turned on.  You would repeat the above for the additional Aux switch circuits.
To try to tie together some other loose ends from this thread -
1)  If you don't want to pay the $$$ for the GM provided leads, TinkeringFox provided part numbers for the terminals themselves back on p.15; that info can be used to make your own leads/wires between the switch/junction block/fuse block.
2)  If you don't have the correct X50A fuse block, or want to create your own fuse block but use the switches, you can stop after step 1 above and then follow some of the posts for "making your own fuse box" in this thread.  The switches are then used as negative triggers on your own relays.
3)  If you have the correct X50A fuse block and you want power in the engine compartment instead of in the cab coming out of the X61A junction box, you can stop after step 7 above, and use the lead coming out of the X50A fuse block to power your loads.
3a)  Furthermore, as TinkeringFox pointed out, you can skip the X61A junction box completely.  In that case, you can skip steps 2, 3 and 4 and wire direct from the S48A X1 to the X50A.  For Aux 1, that would mean a connection from S48A X1 connector in position 12 directly to X50A X3 connector in position M5.
4)  There are at least 2 sellers on ebay that offer the X61A junction block X7 connector pre-wired and in various configurations.  I have no connection to these sellers, but they include dardz2015 and mcasnow.
5)  If you reconfigure your S48A switches, use the information posted elsewhere in this thread in conjunction with the referenced Body Builder Manual to determine the correct position to use in the S48A X1 connector.
Edited by captadamnj
  • Thanks 2
Wiring Schematic1,2
Trigger
Trigger
Output
Output3
S48A
X61A
X61A
X50A
X50A
X61A
X61A
Aux 14,5
X1 - 12
X5 - 10
X1 - 21
X3 - M5
X3 - M7
X1 - 16
X76 - 20
Aux 24,5
X1 - 13
X5 - 17
X1 - 34
X3 - F3
X4 - G2
X1 - 31
X76 - 14
Aux 34,5
X1 - 11
X5 - 11
X1 - 30
X4 - L6
X4 - K5
X1 - 35
X76 - 4
Aux 44,5
X1 - 10
X5 - 23
X1 - 38
X4 - L1
X4 - K2
X1 - 48
X76 - 1
Lead
13575783
19301767
19301767
19301767
19301761
19301761
13575832
2)  If you want power in the engine compartment instead of in the cab coming out of the X61A junction box, you can stop after step 7 above, and use the lead coming out of the X50A fuse block to power your loads.
3)  There are at least 2 sellers on ebay that offer the X61A junction block X7 connector pre-wired and in various configurations.  I have no connection to these sellers, but they include dardz2015 and mcasnow.
4)  If you don't have the correct X50A fuse block, or want to create your own fuse block but use the switches, you can stop after step 1 above and then follow some of the posts for "making your own fuse box" in this thread.
Ok so based on all of this since I do not have the relays in the X50 fuse box, if I add the S48A switches with the four aux switches they will have power I just have to pin pins 10-13 of X1 connector and run those to negative ends of relays?
Yes, correct.  cfields and crazyjoker have some good posts on p.17 about how to use just the switches with your own relays.
Interested in using a switch with Hill Descent Control position as a momentary switch.  My truck does not have Hill Descent Control as a feature currently, but there are wires in positions 3 and 4 of my S48A X1 connector.  If I remove the wire from position 4 and tape it up, should I have any concern about that having impact on operation of the vehicle?  I would then insert a pigtail into position 4 and use that as momentary lead.
Also, for those that have opened up the guts of switches, is it possible to replace the Hill Descent Control switch from a TC/CL/HDC/Aux1/Aux2/Aux3/Aux4 panel with a blank switch from the TC/CL/Aux1/Aux2/Aux3/Aux4 panel and HAVE THE BLANK SWITCH NOT BE FIXED...i.e. have the same capabilities for triggering the momentary circuit but have the switch itself be unlabeled?
Ok so my x1 connector looks like it already has a grey wire in slot 10 and a blue wire in slot 11? What does this mean for me if I’m trying to just bypass the x61 and x50? The only switches I have now are the TC and cargo light.
**Edit** disregard I was reading the connector backwards lol
Edited by Fantastic
Answered my own question about using a blank stationary switch in place of a momentary switch.  The cover itself is what makes the switch stationary.  It is oversized on the back and on the bottom to limit movement.  I was, however, able to trim it down and make it work just like any other momentary switch.  Took me about a half hour with a file, go slow so you don't take too much material.  The bottom is pretty easy, the back takes a bit more patience to make sure you take off enough to allow full activation of the button without taking too much in which case you will loose contact with the button.
Here are the switches after removal...the stationary switch is on the right.  Both a view from the bottom and side are shown.  The yellow outline shows where to remove material, but it is pretty self evident.
5d34f2db199c6_1bottom.thumb.jpg.0a4cd832142788317a6642b24d58b67f.jpg  5d34f2dc588b7_2bottomhighlight.thumb.jpg.d3c1c30ea96db941042f6f612a20ac18.jpg
5d34f2dd86d1c_3side.thumb.jpg.aaac5a2dae16c04e5d0c6e477caffe93.jpg  5d34f2de9aa08_4sidehighlight.thumb.jpg.fd7fffcb2d286020442f7a406e47d757.jpg
And here is a side pic with the two switches after the material has been removed...hard to tell the difference!  (What was the fixed switch is now on the left and now functions identically to other one way momentary switches.)
On 12/30/2018 at 8:31 AM, TinkeringFox said:
Ok, let me get see what I have. Here is the bulletin about the diodes....
With this being said will I be facing the diode towards or away from the switch? If I’m reading the bulletin correctly the cathode is going towards the switch and the anode towards the relay?
There are 7 part numbers for the wiring leads. So if I want to use all four Aux switches I have to order a set of 7 for every switch and then a GM relay for the fuse panel. Correct???
Or call me 314-791-3249
No you only need the cables that were mentioned earlier in the post. You add those to your pre existing connector and then wire those into a relay set up as switched ground.
Hi I bought the part with the traction cargo light and 4 aux switches for my 2014 silvrado 1500 wt this truck comes usually with the two button but I bought the 4 aux button one and I installed it where can I hook the wires from now or how can I find the wires that co trolled by these switches thr junction box pins are not controlled by these in my truck
Might be late to the conversation but my 2018 Silverado 1500 did not come with the aux switch package. I reached out to Chevy to see if it is possible to install them. They said no the truck would have to come from the factory with them. Are they giving me the runaround or are they actually not possible to install?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
