Unfortunately you likely don’t have the wiring you need. There is a pass through nipple on your firewall boot specifically for passing upfitter wiring through. Stealing power from an unused accessory source like power seats, inverter power, ect. might be a viable option. Try to find an option that you don’t have and have no plans to upgrade to. You may be able to source power this way from a fused source.
Edited by TinkeringFox
Hi Guys,
I am impressed with some of your projects and your expertise.  I am not so comfortable figuring out how wires should be installed and really appreciate step-by-step instructions at the level of a 6th grader.  I recently upgraded my 2019 Silverado 1500  LD mirrors to towing mirrors with turn signals.  Got it done because of the help of Mr. Gamboa's harness and instructions. Highly recommended.
I would like to add a 30 inch LED light bar to the front of my truck.  I would like to use the GM 23145158 switch bank (stolen picture attached). Currently my stock switch bank has only "traction control" & "cargo lights."  I do not want to re-label the AUX switches, just want to wire a LED relayed wiring harness to AUX 1 to operate the LED bar.
I would appreciate hearing from you if you can get down to my level.
Selo
On 8/1/2017 at 9:29 PM, smcgillis10 said:
I'm seeing a lot of guys that want to add these switches are having some trouble.
To the guys with ONLY the dome light and traction control switches from the factory be interested in my building a kit for them that they only have to install it into there trucks?
Sent from my Pixel XL using Tapatalk
I’m so confused .. Yes I’m going to have to have you make Me some kind of wire  harness /  relay box .. I tried on my own but ended up drinking the whole 12 pack and said I need to buy something ..  2014 Silverado with the stock traction control/ cargo light .. upgraded to traction control cargo light and 4 aux .. already installed new switch and correct wires in slots 10-14 now what .. Please help
Here’s a relay box for the switch boards with “traction control, cab light, and 4x aux switches” has 5 spots for relays. the 5th relay with trigger with the high beams and Turn on the 2 relays I am using for front lighting.
So the wiring goes from the box to the lights that is the easy part for me. The part that I am having trouble with is from the relay box to the switch.
Which wires ... should be 4 wires on your relay box .. one for switch . One for light , and two powers  that’s  what I understand  I’m having a relay box made and when I have it in hand ill post pictures and maybe can explain it better ...
I’m thinking around the spares battery compartment .. 2014 Silverado .. email Smcgillis10  he is making mine, nothing wrong with supporting a fellow Chevy owner and yes that is where those tiny wires plug into I bought mine directly from Chevy a little pricey I think it’s slots 10-14 but you can double check it’s written somewhere on this thread
Edited by TimmyWeekend
More info
does anyone have the diagrams showing which fuses under hood need to be relocated / installed for this aux switches?
I have a 2016 2500HD WT that came with the switches, I bought the wire harness from GM and plugged it in under the parking brake and ran it out thru the firewall.
seems the GM upfitter website where the pic I need  is down?
thanks
thanks
The relays and fuses should go into the fuse block in the passenger side of the dash.
The switch control the ground side of a relay. You need to have the relay coil hooked to power and the switch will connect it to ground Turing it on.
So i know this is a month old or so but people are still gonna come here and take a look at how this stuff installs, as i did 3 months ago. got around to filling in that list of switches and P/Ns on Page 1. Best I could do, still have some missing... but i hope it helps somebody else when the see it. Cheers and thanks to everybody still on this page posting all the good information. for the record, the Bold dictates the large (wide) keys and regular shows keys that are short/skinny.
I also bought the auxiliary switches for my 2016 Chevy Silverado 1500. I hooked one wire from one of the switches up to the 86 terminal on the relay. The 85 terminal is connected to the positive post of the battery. When I flip all of the switches, nothing happens. Did this happen to you?
Edited by Hudson2000
    btm
    btm
  • Who's Online   4 Members, 0 Anonymous, 1,312 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
