Can you guys give any height gained numbers per setting? So with 4 settings we know the bottom one gives no lift.
What does the 2nd, 3rd, and 4th setting yield?
Not talking about what Bilstein claims but what you guys with experience got. Like after the truck had time to settle what you actually got lift wise per settling.
Edited by NEMESIS-A/T
Just a hair over 2" on top setting for me.
The price you have quoted for a set of four shocks is close to the price quoted for one front 5100 from my dealership!! Has anyone reading tried ordering from British Columbia? If so, what was the final cost?
I hear you, I was in Rossland last month and the pricing on things is very random. I can ship to BC :)
PM sent. I was visiting the Houston area last week and called a local 4Wheel store to inquire about Bilstein levelling shocks. The person I spoke to said they recommend using spacers with Bilsteins set at the bottom (stock) setting. This really struck me as "overkill" but I assumed he knew what he was talking about. All I want at this time is a 1.5" or 1.85" front lift with no negative impact on my suspension. Ideally, I would like this to be an improvement in function as well as looks!
Apologies if this is a repeat, I cannot possibly go back to read 33 pages.
My local shop is suggesting the Bilstein's are not valved properly for the Max Tow/NHT and to wait until Billy or others come out with shocks specified for the NHT.
MRT or others, is that consistent with your understanding? Please and thanks.
Sounds like they are just trying to up sell you in my opinion. Any reasons given?
I believe on Bilsteins site it says not for Max Tow.
Edited by jrob56
No, it was simply a statement that this is the way that they do a level. He sounded quite authoritative and confident. I assume there must be a reason other than a cash grab. He readily gave a price to level with spacers and had the Bilsteins in stock if I wanted them as well.
There's no reason they wouldn't work, other than dampening. I've used 5100's on other "max tow" equipped trucks (Titan) and it was a vast improvement over stock.
Those shocks will bolt on to the NHT truck, they might not have enough dampening to control the rear spring on the NHT tho.
Per this thread, a few users have bilsteins on the NHT equipped trucks.
http://www.gm-trucks.com/forums/topic/162049-nht-ride-quality/
Another good NHT info thread - http://www.gm-trucks.com/forums/topic/172318-2015-silverado-nht-suspension-upgrade-help/
Edited by Mack207
^Thanks Mack, recall seeing something to that effect. I have the airbags coming, but may go ahead and just slap in the non-height adjustable Billys as well, gotta be an improvement over the stocker Ranchos.
Why not? You have something better to do? :lol:
This is correct. I've been looking for replacement shocks as well
Edited by xelli
Has anybody ever experienced a very stiff ride on a freeway? I have bilsteins on the 2nd from top setting with 275/70/18 ko2s running 45 psi. Last week while driving through L.A., the entire cab began bouncing/shaking. Felt as if I had a flat. That was the worst case. Normally on the freeway it just feels like a very stiff front running over a ton of small speed bumps. Best I can describe it.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 429 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
