Any body have trouble getting Camber in specs? What options are out there if so? Upper control arms? Camber kit bolts?
Has anyone looked at these struts? they advertise up to 2.5 of lift versus the bisteins wich lift 1.8 ??
http://www.summitracing.com/parts/eib-e60230060310/overview/year/2015/make/chevrolet/model/silverado-1500
It would be nice to get the look of the RC 2.5 kit without any spacers as the 2.5 kit is exactly the look i like on these trucks
Bilstein's also offer up to 2.75" but this depends on application (brand of truck). On our trucks they are good to 1.85". I think you will find the Summit's claim also depends on application.
I put on 5100s at the max height setting along with BFG KO2s in 275/60r20 and my MPG plummeted 3-4 mpg. Leveling kit and 1 size taller than stock and can't even get more than 18 on highway if I'm nursing it. Averaging 16.5. That's with hand calculating and pretty close to computer after recalibration with Hypertech. Anyone else similar issue? Thinking about lowering 5100s a setting or 2 and getting a lighter tire in stock size back on bc I didn't expect that big a mpg hit.
2015 GMC Sierra 1500 All Terrain SLT 5.3L CC short bed
My truck reads an avg of 14 over 400 miles. Bilstein set at 3rd setting. KO2s 275/70/18. Average 13 mpg in town. Probably less since I haven't adjusted for tire size.
I believe the biggest hit is going from a street tire to a true A/T tire.
I've just read folks doing 2.5" lifts and putting bigger tires than mine on and claiming to get 21+ on highway. Maybe they are full of crap, who knows. My highway is barely more than city mpg. Running all stock I had a 300 mile trip that averaged 23, since these minor mods I can't do better than 18 highway so that's a really big hit.
Edited by Tcolburntexas
What's in your diff? If you have the 3:08 I bet that might be why. Most people with the 3:42 haven't had as much trouble. The 3:08 is built for economy and larger tires and changing angles won't do well with lower ratios
Let us know
3:42 ratio, only 3.42 available in the All Terrain
Ive got 3.42 as well with 2 inch level and I can only get near 20 on highway like 19.5, but I drive 80 and the front end is shaped like a brick now. If I ran 60 I bet id see those 22mpg numbers.
When I go to an AT tire I expect to take a hit though.
Edited by jrob56
Poor fuel economy?
With the larger tires, the speedo/odo counts revs, not distance traveled. Vehicle goes faster/further per rev.
IE the speedo is under-reporting your speed. Also under-reporting distance travelled.
You will need to apply a correction factor using your odometer's readings to get true mileage.
Use a tire size calculator to get the difference between stock and your size.
Apply the correction to your MPG calculations.
Eibach's site info for the shocks - 2"
Summits photo looks like a pic of the rear shock - this is the front shock specs from Eibach's site:
mfg_pro-truck-sport-shock_front.jpg# E60-23-006-03-10
Front: +0-2" rha
Footnotes: Ride Height Adjustable Ring Slots To Allow For A Lift Of 0-2"
Edited by 15silver
Any updates on the 6112's? Last update said end of June.
What was the weight of the previous tire vs new tire.
Its a pretty big jump, think stock is 43ish and that size K02 lists at 54.5.
Stock size K02 is 53.1
    Tonwantonga
    Tonwantonga
  • Who's Online   1 Member, 0 Anonymous, 401 Guests (See full list)
    • I understand that. The price is what it is, though. The price is what oil costs today, where our choices have led us, where supply is, and where demand is, in the market that is. Speculation is for futures, what we think the price will be, but with incomplete information at the time the price is forecast. I know you know this, but you appear to be intent on making a secondary point here about what you think the market could or should be, if only other choices.   In 1975 it became illegal to export US Crude. I'm conflicted on what the best answer is. Free markets allow export in pursuit of profit. But there is also a lot to gain by producing and consuming our own oil here. How do you reconcile it?
    • That sir is a choice. And even if it were not for all the reasons stated, this disruption has zero to do with the reality of the actual logistics and everything to do with the greed of SPECULATION. Spot price is irrelevant to reality.
    • What I think you're saying is there is supply here at home, and in Venezuela, and we could ease pricing if only it were favorable to do so.   Well, yes?   But that's not the current market. Supply isn't what could someday exist, if only, it's what producers are willing to produce and sell at a certain price point.   The national price of single family homes would come way down if we'd just slap together a few million homes this summer.   RAM and GPUs would get a lot cheaper if we just set up some factories to produce a bunch more and stopped using it to build out AI data centers.
    • The turn signal/multifunction switch is faulty.  I've seen a few of these go bad at work.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
